Results 16 to 30 of 35
Thread: Engine backfires then stalls.
    Jan 2007
    Hammond, Indiana - USA
    I always put a piece of tape on both sides of each electrical connection, and mark them with a number. Makes it easy to insure there are no mismatches on assembly.
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
    1983 Yamaha XJ650LK Seca Turbo
    2006 Yamaha FJR1300AE
    Jun 2010
    NJ
    Quote Originally Posted by Diablo1 View Post
    I did the same on the coil side, ended up doing same on the harness side after I had them reversed.
    Sent from my iPhone using Tapatalk Pro
    37 miles E. of ATX, TX USA.
    If the injectors are simply out of sequence (plugged into wrong cylinder) cold start is slightly more difficult but once up to temp there is almost zero difference in riding feeling. The cylinders are still getting fuel and once warm it’s pretty well atomized either way. My first EFI equipped bike fired all injectors with each crank rotation. 84 Kawasaki GpZ750 Turbo.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jun 2011
    Central Cali.
    Water in a spray bottle, start bike, squirt headers, find the cold one....replace injector if needed.
    Problem is bike stalls before I can squirt water on the headers.
    Sent from my iPad using Tapatalk
    Apr 2010
    Andover, UK
    If you've unplugged the PCV then i would try spark plugs as mine was hard to start and then wouldn't and it just backfired. Changed plugs and the bike was whole again (Even though they produced a spark on my dirt bike).
    Fire up, hold throttle at say 2-5% opening. Keep rpm under 6k. Test.
    make sure crank position connector is reconnected like stock
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jun 2011
    Central Cali.
    Update,got the bike started and sprayed the headers and both rear cylinders were cold. Where can I get the injectors at a low cost? And are lower and upper injectors the same?
    Oct 2015
    Tasmania
    The upper & lower injectors are different.
    Part number for lower injector is 893934 or GU05115730 https://www.af1racing.com/store/Scri...29&action=View
    You maybe get some on ebay.
    strange for both to fail at the same time.
    Are you sure something else like a bad connection somewhere isn't causing the issue.
    Have you read the error status in the ECU with IAW/GuzziDiag or PADS?
    Injectors have individual error codes; so if they both have failed it will be recorded in the ECU.
    Jun 2011
    Central Cali.
    I have guizzidiag but don't know where to start to get the error codes if any.
    Sent from my SM-G955U using Tapatalk
    Oct 2015
    Tasmania
    Quote Originally Posted by letsride View Post
    make sure your cable has been installed by the Laptop OS so drivers are installed.
    plug in the diag cable (diag plug is in the tail section just under the pillion seat/tail lock);
    open IAW/GuzziDiag,
    if this is first time you use it;
    select File/preferences;
    select the correct com port.
    select Motorcycle 7SM for IAWDiag, California 1400 for GuzziDiag.
    Close that dialogue.
    Go to File/Connect, Turn ignition on, select OK.
    You should see a bunch of numbers appear in the main page & at the bottom it will confirm connected.
    Now Select, View/ Faults.
    Select Read, any Active faults or Stored faults appear as a code.
    Write them down or take a screen snip of them.
    Clear faults.
    Select file Disconnect, shut off ignition.
    Look faults up in the Service Manual, bingo.
    Jun 2011
    Central Cali.
    Sweet,thanks. I'll try that out this week.
    Jun 2011
    Central Cali.
    These are the codes that popped up.
    Oct 2015
    Tasmania
    Ok so they may be new or old, being in stored. See below what they mean.
    So now clear them, & then with Guzzidiag connected to bike, start the engine or attempt to at least & then read errors & see what pops up.
    DIAGNOSTIC TOOL: LOGIC ERRORS
    Starter switch P0169
    signal not valid.
    Error cause
    Fault in the switch (lock) of the engine start-up. The instrument panel does not indicate the
    presence of this error even in the ATT status.
    Troubleshooting
    Check the locking cause and restore.
    CAN line towards instrument panel U1701
    no signal.
    Error cause
    No signal is received from the instrument panel.
    Troubleshooting
    Check the connector of the instrument panel: if not OK, restore; if OK, check the continuity
    of the two lines from the instrument panel connector to the VEHICLE connector of the Marelli
    control unit: if not OK, restore the cable harness; if OK, replace the instrument panel.
    CAN line towards instrument panel U1702.
    Intermittent signal or communication error.
    Error cause
    Probable bad contact in the CAN line.
    Troubleshooting
    Check the Vehicle connector pins 66 and 80 and the vehicle-engine cable harness pins B2
    and B3. If not OK, restore. If OK, check pins 26 and 27 and the instrument panel connector.
    If not OK, restore. If OK, check overall operation of the Marelli control unit and instrument
    panel: replace the affected component if you find any fault
    Jun 2011
    Central Cali.
    No error codes popped up
    Oct 2015
    Tasmania
    No errors indicates, no current electrical problem.
    Does the engine start & run now?
    If the bike still isn't running on those 2 cylinders then logic would point to blocked injectors, maybe??
    Or spark plugs, do you have a couple of new plugs to throw in the rear cylinders to eliminate that?
    Are you 100% sure you haven't got the rear coils connected opposite?
    It would be more likely something you did when installing the PC.
  1. Engine Cut Out/Stalling - Does the 2013 New Map update fix
    By Troytheboy in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 04-08-2014, 10:53 AM
  2. Engine stuttering (almost stalling) when hard on the brakes?
    By Fangit in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 06-20-2013, 09:17 AM
  3. Still backfires and stalls :(
    By joeybeppy in forum RST1000 Futura (all years)
    Last Post: 06-02-2013, 06:35 PM
  4. Engine backfired and now doesn't want to idle smoothly....
    By ride200mi in forum RST1000 Futura (all years)
    Last Post: 01-04-2011, 12:48 PM
  5. Red Caution and EFI warning Then Stall On Sportcity 250
    By scrider in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 02-04-2010, 08:06 AM
