Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Engine backfires then stalls.
    Jun 2011
    Central Cali.
    I have a 2013 rsv4 that I just installed a power commander. When I went to start it,it fired right up and then backfired and stalled. Tried to start it again and it would just stall. Anyone ever encounter this or have a solution to trouble shoot it?
    Apr 2014
    Louisiana, US
    First thing I would do is uninstall the pcv and see if the bike is responding like normal. Odds are the wiring harness that goes between the injectors and pcv is having an issue or a defective module if you have the proper map pre loaded. Imo i'm not a fan of pcv units but they do work. I'm more of a fan bazzaz or rapid bike units if you have to use a piggyback type module preferably rapidbike.
    Apr 2010
    Andover, UK
    My bike was misfiring and running poorly and i checked and cleaned my plugs. After i put them back it would stay running, then wouldnt start and just backfired so i changed my plugs and this fixed it. It had been in storage for a few years and want started. I put CR9EB into my bike.
    Have you unplugged the Power Commander to see what she does without it? Could be the MAP installed on it, maybe. Not been on their site for a while but when i had an R1 you could download a generic map onto the Power Commander and then id take it to a rolling road for tweaking.
    Jun 2011
    Central Cali.
    I’ll try removing it and see what happens,
    Jun 2011
    Central Cali.
    Have remove the power commander and is still doing the same. I'm wondering if I switched the fuel injector wiring around. Does anyone know which goes to each injector or have a wiring diagram to see if that's the problem?
    Sent from my SM-G955U using Tapatalk
    Oct 2015
    Tasmania
    Injection connectors.
    Cylinder 1 Left rear = Black
    Cylinder 2 Left front = Brown
    Cylinder 3 Right rear = Green
    Cylinder 4 Right front = Light grey (almost white).
    Same colors for upper & lower injectors.
    Jun 2011
    Central Cali.
    Thanks,ill check it tomorrow
    Sent from my iPad using Tapatalk
    Apr 2010
    Andover, UK
    I wrote the colours on my airbox lid when i took them off...proper paranoid....lol
    apriliaforum expert Proctologist's Avatar
    Oct 2014
    Tri-State USA
    Quote Originally Posted by letsride View Post
    Have remove the power commander and is still doing the same. I'm wondering if I switched the fuel injector wiring around..
    Best to retrace your steps, especially if it ran good before the power commander endeavor.
    Today:
    Ducati 1199 Panigale Rosso | Aprilia RSV4-R APRC ABS | Aprilia RSV 1000R (under construction)
    Yesterday:
    Ducati 1098 | Suzuki GSX-R1000 | Suzuki GSX-R1100 | Kawasaki Ninja ZX600R | Suzuki TS185
    37 miles E. of ATX, TX USA.
    You likely cracked an injector electrical socket. I see this OFTEN with Bazzaz and PCV on the Aprilia V4 motors as there is next to zero available real estate under the tank. I’ve probably replaced 6 injectors this year already. Wiggle each connector gently, if one attached to a fuel injector moves much at all, likely broken.
    Oh oh and make damn sure all fuel hose quick connectors are FULLY plugged in.
    Final test as others have stated, unplug PCV from injection and retest.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jun 2011
    Central Cali.
    I have removed pc and checked the wire harness and they were all connected correctly,how can I check for cracked injector harness? Wiggled the connectors and all seam fine.
    Water in a spray bottle, start bike, squirt headers, find the cold one....replace injector if needed.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jun 2011
    Central Cali.
    I'll try that,thanks.
    apriliaforum Junkie SlamDunK's Avatar
    May 2010
    Lancashire, UK
    Quote Originally Posted by marc.r1 View Post
    Nope, just sensible.
    I use my phone, take pics and refer back if stuck.....
    Jun 2010
    NJ
    This.
    Also, it's easy to get the rear bank coil connectors backwards. There's a page in the manual that tells how to determine which one is which.
  1. Engine Cut Out/Stalling - Does the 2013 New Map update fix
    By Troytheboy in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 04-08-2014, 10:53 AM
  2. Engine stuttering (almost stalling) when hard on the brakes?
    By Fangit in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 06-20-2013, 09:17 AM
  3. Still backfires and stalls :(
    By joeybeppy in forum RST1000 Futura (all years)
    Last Post: 06-02-2013, 06:35 PM
  4. Engine backfired and now doesn't want to idle smoothly....
    By ride200mi in forum RST1000 Futura (all years)
    Last Post: 01-04-2011, 12:48 PM
  5. Red Caution and EFI warning Then Stall On Sportcity 250
    By scrider in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 02-04-2010, 08:06 AM
