Results 1 to 11 of 11
Thread: Advice wanted: engine swap or not?
    apriliaforum Member joost.bijl's Avatar
    Delft, NL
    I have a dilemma: should I swap engines or not?
    The situation is that my current engine (with 85kkm) has some issues:
    • Most serious is a rattle in neutral at low RPM, and under load at low RPM. I changed the clutch house bearing but that made no difference. My assessment is that a larger bearing in the gearbox is likely going bad. Fixing that would require an engine removal and splitting.
    • Engine is using a little oil, in the range of 1 liter every 8-10kkm
    • Shifting is clunky, especially compared to other Capoís. Finding neutral is really hard. (I did not do the oil jet swap from 60 to 40 yet)
    • The ground point on the front cylinder is helicoiled by the previous owner.
    • Itís time to check valve clearances
    • I want to inspect and clean cam chain tensioners.
    I was able to buy a similar mileage engine with no known issues for less than the price of a gasket set. I had the intention of preparing this one and then swapping it. Since the engine is out of the bike itís easy to do valve check/adjustments et cetera.
    Yesterday I was at the dealer and asked his opinion. He was pretty sure the problem with the low rpm rattle was due to some play between the clutch basked and the clutch gear on the primary drive. Something that will gradually get worse over the next 10k-20k. When your bike sounds a little bit like a ducati it's time to fix it. If this is really the case it would be a whole lot easier/quicker to just swap the primary drive from the donor block and be done with it.
    Given the fact that Iím no professional and never done an engine swap I see some risks:
    • too difficult: may end up with a non working motorcycle
    • not necessary: just swapping clutch baskets would be good enough too
    • takes too long: I planned a bike holiday in 3 weeks
    So that gives me 3 options
    1. Proceed with engine swap
    2. Only swap clutch
    3. Donít swap anything and just ride, for now
    What do you guys recommend?
    Ireland
    If you knew what is was that was wrong with it and fixing was cheaper than a replacement engine, then yeah fix it. But when you're uncertain and you add in the oil consumption....me I'd swap it. I've never swapped a rotax aprilia but sure take your time and do as the manual says. Perhaps a futura motor!?
    Brum Brum
    Delft, NL
    Thanks the_toe_cutter. I tried to extract the clutch basket today, but it won't fit through the side panel. So far for a quick clutch change .
    Dec 2007
    Cumbria
    Ride for now. Change the engine after your bike trip.
    08 ETV 1000 Caponord
    NC705X DCT - The Blue Toad
    Honda PCX125 - White Lightning
    Jun 2009
    oldham uk and soon gibraltar
    Grant swapped mine out in about 6 hours from ride in to ride out I’ve done one myself and it took me 2 days but not full days probably 10 hrs in total but I didn’t rush
    Mar 2018
    California
    Like Nerald said.
    Thing with repairing is unless you are prepared to go over everything then the next thing that goes becomes a real turd from a repeat effort standpoint.
    Once the tank is off...
    Will the bike make the trip as is? Do that. Then swap and futz with the old engine as you please.
    apriliaforum expert Leanit's Avatar
    May 2005
    San Francisco
    Ride to California. I'll give you my spare engine.
    Mar 2018
    California
    Did I read spare engine? Decent shape and miles I presume?
    Apr 2019
    DFW, TX
    • "Engine is using a little oil, in the range of 1 liter every 8-10kkm"
    • 10kkm is (if my rusty metric conversion skills are correct) 6250 miles. I have never run that far between oil changes in any vehicle I have owned in 50+ years (nearing 100 bikes and more than a dozen cars/trucks in that time). A liter of oil in that mileage, I don't think I would be concerned about. A liter in 3,000 miles (my usual oil change interval) I have heard of, and might be concerned with.
    • I would not swap into an unknown engine just before a trip. Perhaps ride what you have on the trip, take it easy, and when you return, re-evaluate and decide which way to go.
    • Me, I would consider tearing the "new" engine down, at least pull the heads and have a look at heads, valves, cylinders and rings. If you bought it for less than the cost of a gasket set, then buy a gasket set, have a look inside and (depending on the results) install it after the trip...and take it easy until you trust it...and then enjoy.
    May 2005
    San Francisco
    Good shape as far as I know. Came from a crashed bike near Santa Cruz ages ago, but there's no injury to the engine from the crash. Can't remember exact mileage, but I think it was in the 10k-15k range. I've never heard it run, but it was obviously running when its original chassis got hit.
    Has wiring, ECU, etc. Coils too, I think. Since I bought it, nothing on mine has failed. Figures.
    Mar 2018
    California
    It's like that, the part you have spares for will never fail. Possibilities if you want to part with it. I have so many spares just a frame and engine would make another bike, literally. I've been adding to the pile I got from Matt.
  1. Race ECU straight swap or not?
    By leepts in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 01-19-2019, 09:21 AM
  2. Wheel Color Swap or Not
    By Fox Fader in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-31-2016, 11:10 PM
  3. Electrical Tape use around the (hot) engine - acceptable or not?
    By FreshAir in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-11-2015, 09:20 AM
  4. Engine damage or not after clutch disaster?
    By benuk in forum SL1000 Falco Forum (all years)
    Last Post: 05-01-2012, 03:00 AM
  5. Need some expert info on this 70cc engine. Shot or Not?
    By krisnet in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 12-31-2007, 09:56 PM
