Results 1 to 9 of 9
Thread: 7000 + rpm engine spluttering problem
    apriliaforum Member coopz78's Avatar
    Jan 2017
    surrey U.K
    Hi, i have a problem with my sxv 550. Bike start up 1st time and runs as normal below 6000-7000 rpm but occasionally as i open throttle up engine stats to splutter like there is an issue with fuelling.............
    I've change sparks and checked coils with multimeter.
    Im thinking fuel injectors? or fuel pump?
    apriliaforum Junkie undergrounder's Avatar
    May 2015
    holland
    Tps throttle position sensor could be bad.
    search the forum for it, as it has been discribed in many topics before
    My bike is my gym, my wheelchair and my church all in one. I'd like to ride my bike all day long but I've got this thing called a job that keeps getting in the way.
    Jan 2017
    surrey U.K
    Quote Originally Posted by undergrounder View Post
    Thanks will do
    Jan 2017
    surrey U.K
    Quote Originally Posted by coopz78 View Post
    Thanks will do
    just realised the barometric pressure pipe was not connected to the outside of air box.
    do think this could be probable cause?
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    I don't think so. In my opinion there are two possible causes:
    - problem with TPS/harnes
    - problem with crank sensor
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
    Jan 2017
    surrey U.K
    Quote Originally Posted by levisik View Post
    ok thanks for your help
    apriliaforum Junkie SXV_Jack's Avatar
    Jul 2018
    germania magna
    i had this too and after correktion, the engine runs better.
    have you made a test drive ?
    TPS and CS is also something to check ... i remember that i read bad CS makes problemem primary on high U/min.
    Jan 2017
    surrey U.K
    Quote Originally Posted by SXV_Jack View Post
    update, reconnected barometric hose to out side airbox. I also recently put some injector cleaner in the fuel.
    Road it today for 25 mins and didn't have an issue. Weird!!!
    Also, on few occasions mid ride after stopping for coffee go to start the bike and starter relay just clicks........... so i put it in gear and roll it forward and hey presto it starts!
    Jan 2017
    surrey U.K
    Update - bike running as it should now. I think the injector cleaner and reconnecting barometric pressure tube fixed the problem.
    Thanks for all the help
  1. Engine/Revs problems!! Help??
    By 2000rs50 in forum RS50 Technical
    Last Post: 09-01-2006, 04:51 PM
  2. surging between 5000 and 7000 rpm
    By Elridor in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 06-07-2006, 03:55 AM
  3. Engine heat problem - is it true?
    By hass in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-09-2005, 03:12 PM
  4. High RPM engine failures...
    By keean in forum RS250
    Last Post: 09-01-2004, 09:50 AM
  5. Spluttering problems
    By Mark7X7R in forum RS125 Euro-archive
    Last Post: 08-11-2003, 03:24 AM
