Results 1 to 5 of 5
Thread: sr50 70 kit running hot
    May 2014
    walsall
    techno gas exhaust not sure what model
    Piaggio NRG 50 Power DT AC 07-09 17.5mm Carburettor with Auto Choke
    70cc cast iron cylinder kit from Naraku for Piaggio
    put a 96 jet in carb and not boging now starts rides ok 1/2 turns on air screw needle in midle position plug brown but seems hot, exhaust muffler to hot to touch is this normal as not run in yet tried a 103 jet but starts and cuts out .
    6.3 gram rollers red spring thinks may need lighter rollers and blue spring after tuning
    May 2014
    walsall
    Open filter on that carb will cost you power. Figure out what exhaust you have and filter and if the carb needle is the stock A22. Because it sounds opened up and not able to spin stock rollers? So it is not tuned yet. The airscrew helps you find problems yes but it must be around 1.5t to function correctly
    Tecnigas Next-R looks like this exhaust
    Have standard filter and stock needle pulling ok with rollers in hills etc but seems slower than my derestricted lionovince exhaust sr50 ditech
    apriliaforum Member rank1's Avatar
    Mar 2019
    Hungary
    If the plug seems hot then try colder one.But rejet the carb for sure.
    May 2014
    walsall
    re jetted to a 100 but still running hot wondering if cramk seals are ok but pison i took out was ok there was a restricter brass ring in other carb wich i have left out of new carb
    Mar 2019
    Hungary
    coolant bleed it properly?turn on the engine let it idle and use break cleaner around intake,cyl.about seals u should check both sides.the most of the time crank seals on the ignition side worn out.just buy a new one and replace it.do u premix?dont mix too much oil cuz it ll run leaner.
  1. has anyone run a hebo manson 70 kit
    By swedish89 in forum RS50 Technical
    Last Post: 06-06-2008, 07:05 AM
  2. running hot...
    By SiR50 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-07-2005, 01:30 AM
  3. Running HOT (Help)
    By TOOL in forum SL1000 Falco Forum (all years)
    Last Post: 06-27-2004, 09:14 PM
  4. will malossi kit run with stock...
    By RSr in forum RS50 Technical
    Last Post: 12-05-2003, 01:14 PM
  5. MK 70 kit and 21mm carb
    By bengould in forum RS50 Technical
    Last Post: 09-05-2003, 07:57 AM
