Results 1 to 15 of 15
Thread: Just the motor oil or oil in the tank too? Drain to take out starter?
    Nov 2011
    LI NY
    Just changed the oil 10 min before the starter went poop. Can I just drain from the bolt on the motor or do I need to drain oil from the tank too so I donít make a mess?
    Iím super bummed right now. Today was the day I thought Iíd have wind in my face.
    apriliaforum Junkie abarth's Avatar
    Oct 2008
    Serbia, NS
    You want to take down starter? If so, no need to drain oil at all....
    Nov 2011
    LI NY
    Really? Today I read that it’s necessary to drain the motor oil on the sxv to take out the starter here on the forum.
    Nov 2008
    Western Australia
    Nope...
    Been swapping starters back and forth all week without draining a drop...
    Nov 2011
    LI NY
    Thank you very much guys!!!!
    Feb 2009
    Tri-Cities, Washington
    As stated, no need to drain oil, but if there is a significant amount of oil in the case it may leak if you donít lean the bike to the right hand side or stand vertically.
    Take your starter apart and see what went wrong before you start throwing money at it. It may be something easy like a good cleaning.
    Nov 2011
    LI NY
    Thanks! I have a rear stand and will pop it up. The bike only ran for a minute after the oil change. Will report back.
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    Just put it next to wall on some degree. It even will be easier to take starter out.
    Cheapest starter is from chineese skuter 125, but it rewuires more labor
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
    Aug 2017
    Portland, Oregon
    How do you drain the tank. All the oil change docs I've seen, you just drain from the motor.
    Sent from my MI PAD 4 PLUS using Tapatalk
    Feb 2009
    Drain bolt and sealing washer right on the bottom of the tank.
    Aug 2017
    Portland, Oregon
    Quote Originally Posted by SXVINWA View Post
    Is this mentioned in the oil change howto?
    When I drained mine I just drained out of motor. I had to fill with slightly more than specified to get correct on sight tube so I assumed I'd drained everything.
    Nov 2011
    LI NY
    I do believe this is in the how to section. Drain motor oil from the tank and the case. Drain the gear oil from the case.
    Quote Originally Posted by crazybrit View Post
    Nov 2011
    LI NY
    Do you have a starter besides the OEM that you would recommend?
    Quote Originally Posted by S4R View Post
    Nope...
    Aug 2017
    Portland, Oregon
    Quote Originally Posted by ceosurfer View Post
    Okay, I see it now in the antbreon version (in the howto thread) but I don't recall seeing mention of draining the tank in the irie PDF that sxvinwa sent me, or in the owners manual. I'm not at home right now to check the irie "oil change procedure" pdf, I'll have to check it again when I get home.
    apriliaforum Junkie undergrounder's Avatar
    May 2015
    holland
    I never drain the oil tank only the oil drain on the left and I take out the the fcv valve at the bottom.
    The oil from your oil tank (correct me if I'm wrong) flows towards your fcv valve.
    My bike is my gym, my wheelchair and my church all in one. I'd like to ride my bike all day long but I've got this thing called a job that keeps getting in the way.
  1. motor oil in gear box why?
    By KTMJACK in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-02-2014, 11:13 AM
  2. the route i want to take on tuning my rs125 any thorts
    By 13R4D RS125 in forum 2009 RS125-USA
    Last Post: 02-08-2014, 02:03 PM
  3. Need tank bag that sits up off the tank, maybe attached to gas filler?
    By scott2ride in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 07-19-2012, 11:57 AM
  4. quick question (re: oil in fuel tank)
    By repsolhonda46 in forum RS125 Euro-archive
    Last Post: 02-02-2004, 08:00 AM
  5. Oil in catch tank (technical topic)
    By beanarillo in forum RS250
    Last Post: 10-22-2003, 03:10 AM
