Results 1 to 5 of 5
Thread: AWC settings fault/Error
    apriliaforum newb Gees's Avatar
    Jul 2019
    Sweden
    Hi, first time here but been lurking around the threads for a while.
    The bike is a RSV4-13 Factory
    I have a problem when choosing the settings in the menu for AWC and ALC
    I can reach the menu and I can set the AWC for example to 1, but when browsing thru the menus down to ABS the AWC automatically turns back to 3.
    I have run the guzziDiag and it doesn't get any fault codes from it, original ECU with what suppose is the OEM Map 1338AB13.
    Any one experienced a similar problem?
    Oct 2015
    Tasmania
    Well welcome to the forum former lurker.
    That is one weird thing going on there, glad you videoed it.
    Your bike is haunted, you may need an exorcist. lol
    Things I would try;
    Disconnect battery for a couple of minutes & reconnect. (you will need to reset your clock)
    Try turning off AWC for a few rides & see if it solves the issue.
    Turn off ATC & cycle the ignition a few times with time in between, ride the bike with it off, then turn it all back on.
    Check all earth/ground wire connections.
    Check connectors for corroded contacts at the back of the Dashboard & at the ECU.
    Check for any other sign of wiring harness damage.
    Check charging system voltage & battery health.
    EDIT; you have the old map, 1338AB13, on your ECU, updating to the latest map, 13A9AB23 or the Race map 13A9AD23, may also solve your issue.
    Jul 2016
    Poland
    What Plocky said, my two cents are that You can try to set AWC & ALC, both to 2 (tamper with it a bit). But it sure looks like a software issue, so next best bet is to flash it. I have same bike, same year, didn't have that issue on stock mapping but that was brief as Tomik flashed mine to Race coz of the Akra i have.
    Jul 2019
    Sweden
    Ty
    The exorcist thing is one solution that crossed my mind!
    Things I would try;
    I actually did this, because I charged the battery on the shelf while doing some other work on the bike.
    All tho i did measure low voltage on it after firing it up around 12-12,2 volt
    Been away now for 3 consecutive trackdays and changed the AWC to 1 and instead of toggle the menus went back to normal display mode, and the setting seemed to stay on 1 that way.
    but as soon as I went back and changed any other setting it turned back to 3, but if I let it be it stayed put on 1
    Same result as the video, turned everything off, also tried to do it in the "menus" section where you change all the other stuff
    Cleared all connectors from ECU/regulator no change
    This, I hope its a failure in the map, i have downloaded the map in the ECU to send it away (not all sure to who, but I think its in the Guzzidiag thread on whom I should send it?)
    since a want the race map anyways with full system on the bike.
    Gotta mention that its a trackbike only, so I have done some testing outside the garage but I cant do that to frequently since it is in the middle of the city.
    / G
    Jul 2016
    Poland
    You can flash the ECU Yourself, just read and understand the guzzidiag thread.
    The cables cost around 30$ on ebay and You can do additional things, like diagnostics etc. (but i reccomend loneltec as I did test them).
    BTW when You read Your map I'm interested if the sha or md5 will match any map that Paul has, as to see if it's glitched (hope not), or worse, You have ecu issue, like corrupted part of memory chip.
  1. ATC & AWC setting for wheelies & ride
    By Zdipi in forum 2010-2019 RSV4 - All Variants
    Last Post: 09-26-2018, 04:48 PM
  2. Light fault error 16 RF
    By skitz0 in forum 2010-2019 RSV4 - All Variants
    Last Post: 02-20-2018, 01:54 PM
  3. OEM Recommended settings for Ohlins shock. Error in Manual?
    By antarius in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 10-28-2017, 11:51 AM
  4. DSB 03 error / fault Active
    By Gbyte666 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 07-16-2015, 01:44 PM
  5. Setting TPS (error codes 3,4,5,6,7,8)
    By khrys in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-17-2015, 03:58 AM
