Results 1 to 3 of 3
Thread: Sportcity 125 swap to 200
    Jun 2019
    uk
    Hi guys,
    What would be the best way to tune the 125?
    Am I correct in thinking that if I just swap cylinder with a 200 I should make easily few extra hp?
    What would you do for best bangs for bucks?
    Thank you
    apriliaforum Member greg531's Avatar
    Feb 2011
    Grand Pot Hole Rapids, MI
    The easy way, would be selling that 125, and buying a 200 or 250.....
    2009 Aprilia Scarabeo 200
    2005 70cc Typhoon
    1963 Vespa GL
    http://www.grscooterclub.com/
    Clearwater, Fl
    You would also rejet the carburetor at a minimum and put slightly heavier rollers in the variator. The metering rod on the carburetor slide will likely need adjusting also.
    Easiest and best would be to just keep an eye out for a SportCity, Scarabeo or BV 250 and trade the 125 in.
  1. 2007 RS50 to RS4 125 swap possible?
    By RSVMille1000 in forum RS50 Technical
    Last Post: 05-04-2017, 08:38 PM
  2. Sportcity 125 upgrade to 300
    By agilebda in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-08-2016, 03:52 AM
  3. Sportcity 125/200/250/300 Puig Screen and Akropovic exhaust
    By ride4321 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 03-17-2016, 12:28 PM
  4. Variator swap 125 to 200
    By andreatalo in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-08-2012, 06:54 AM
  5. Help needed, Sportcity 200 engine swap to 250ie or 300 Quasar?
    By 930turbo in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-04-2011, 03:54 AM
