Results 1 to 4 of 4
Thread: Radial master cylinder,
    Feb 2015
    United Kingdom
    Is there a radial master cylinder available that would improve the stopping power, ? Using Std discs and red brembo pads at the moment, looking to improve on that . Thanks
    Sweden, Linköping
    I would say no.
    Its more of a feel thing a radial pump can help with.
    Read my signature below.
    Blueridge GA, USA
    Biggest 'stopping power' improvement for my Fut was Brembo SC compound pads. (From Carpimoto)
    Also have braided lines, radial master, & aftermarket rotors.
    '02 Futura, Blue
    99.5k miles and ok, it's old.
    Aug 2006
    Santa Cruz, CA
    "Stopping power" is relative.
    Will a radial m.c provide more?
    No. Either will stoppie that bike.
    But a good radial unit--like Deefred's (and mine) Duc 999 unit, especially combined with Brembo 4-pad calipers--will shift and accelerate that stopping power.
    One finger, nuts to the tank.
  1. Brembo radial master cylinder
    By Jobu137 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-06-2006, 10:50 AM
  2. radial master cylinder
    By keean in forum RS250
    Last Post: 05-05-2005, 09:54 AM
  3. brembo radial master cylinder
    By tt dave in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-21-2005, 08:51 PM
  4. brembo radial master cylinder
    By gsxr600james in forum RS250
    Last Post: 10-02-2004, 07:40 PM
  5. Brembo Radial Master Cylinder
    By mikesolomonusa in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-03-2003, 11:51 PM
