Results 1 to 5 of 5
Thread: Number of triggers on the RST speed sensor
    Washington State USA
    I was hoping someone on here has knowledge of the number of nodes the Futura uses for the speed sensor to read and compute the mph?
    My Capo flashed back to Euro Futura ROM and I was hoping to devise a work around so another flash doesn't cripple the speedo.
    The Capo reads the bolt heads holding the rear disk on and I was going to add a thin stainless steel disk under the bolts with added metal studs to match the Futura node count. A shim of the same thickness would be added under the speed sensor itself to adjust the spacing.
    Thanks ahead of time for your help.
    KB
    Sweden, Linköping
    32 nodes per wheel revolution.
    May 2019
    Moscow, Russia
    You could reflash it with a right Capo values.
    Look here https://kickstarter.org/forum/index....8125#msg428125
    English is not my native language, so please be kind to my mistakes.
    Remember, this is an Italian bike with an Austrian motor, it isn't like the GSXR you use to own...
    iamdude:
    That link is in Russian which I am not fluent in.
    KB
    Aug 2006
    Santa Cruz, CA
    Thank you Deefred. That is an outstanding little bit of data to have.
  1. Best way to get rid of rust on the bike?
    By ApriliMo in forum RS125 Euro-archive
    Last Post: 02-04-2004, 07:29 PM
  2. Bit of news on the Bef relocator
    By Befbever in forum RST1000 Futura (all years)
    Last Post: 01-16-2004, 03:27 PM
  3. Dave Despain's point of view on the lack of motorcycles on Speed
    By mfield2a in forum General Motorcycle Talk
    Last Post: 12-11-2003, 09:44 PM
  4. looking for the right speed sensor wire
    By Dood in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-16-2003, 11:23 AM
  5. So what the bit of plastic on the Aprilia keyring for?
    By Jon CAKE in forum Pegaso 650 Cube and IE
    Last Post: 10-25-2002, 01:21 AM
