Results 1 to 6 of 6
Thread: Shiver shutting down when in bad mood
    Jun 2019
    Italy
    Hi guys,
    I'm struggling with an issue on my Aprilia Shiver 750 year 2007.
    Basically, when in normal working temperature the bike turns off when idling.
    For example I take it in the morning, I turn it on and start driving. After a while, while everything looks fine, if I stop (e.g. traffic light) or I'm using the clutch (e.g. I'm going slow in the traffic), the bike turns off. Most of the time I'm able to start it.
    But sometimes the "SERVICE" signal appears with the warning light and In that case the bike doesn't start; I would need to wait a bit (sometimes a few minutes) to be able to start it again. At the next power on the warning light goes off by itself.
    I thought it was because of the spark plugs, but today I changed them and still I got the same problem after some driving.
    Do you have any idea what can I check next or is it just bad mood?
    Thanks!
    PS I just ordered the cables to connect with my PC to the control unit, so that right now I can't check what the SERVICE and warning light mean.
    Nov 2016
    Lincoln
    Reading the codes should tell you where to look.
    Otherwise, unfortunately (e.g. if it's heat getting to a sensor) it could be anything! Check the obvious things like fluid levels, battery voltage and fuel tank breather pipes etc. Look for signs of damage, particularly on wiring / connectors.
    2009 Shiver (White) | UK
    apriliaforum expert LesRiskey's Avatar
    Jul 2016
    Yorba Linda, CA
    Air filter?
    You don't need to earn my respect.
    I give it freely.
    Whether or not you keep it is entirely up to you.
    Jul 2009
    AUS
    I have a similar problem but no light only on Idle it sometimes shuts down ,I am not sure it sounds like a sensor is failing you could also try this forum there is another one German if my memory is good they helped me a lot ,the guzi diag will give you the errors that are stored it's a great help.https://www.italobikes.com/de/foren/2-aprilia-forum
    Jul 2007
    Kapiti, New Zealand
    I wonder if its the sidestand / gear position / clutch lever interlock. If it shuts down promptly, like pushing the kill switch, this is what I would look for. Start with the microswitch on the sidestand.
    Frodo
    2015 Shiver
    New Zealand
    Jul 2017
    Canada
    On my bike when this happens it's a fault in the accelerator handlebar twist sensor thing. Usually restarting the bike makes it go away for awhile
    Sent from my LYA-L0C using Tapatalk
  1. Bad idle/engine shut down
    By Dirty Damien in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-05-2017, 01:49 PM
  2. 2014 RSV4 Factory Shuts Down Engine When Riding
    By Shwagg in forum 2010-2019 RSV4 - All Variants
    Last Post: 03-27-2016, 01:12 PM
  3. Aprilia SR50 2006 Shuts down when engine warms up
    By huryt in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-26-2014, 03:23 AM
  4. Clutch in while riding and engine shuts down
    By llzjayarzll in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 05-01-2013, 12:15 AM
  5. 84 miles and shiver shuts down...
    By esperDrilz in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 01-25-2010, 07:05 PM
