Results 1 to 14 of 14
Thread: Odd drips under my 2009 Scarabeo 200
    Apr 2016
    Dallas
    I'm hoping some of you can help me identify just what might be dripping out of Scarabeo 200. I first noticed that something was running down the center stand, but just here and there. In the last week, there have been a few more steady drops on the ground, right when put it up on the stand after a ride. Seems light in color and oily, so my first thought was liquid coolant but my operating temps have remained fairly normal. I am at about 14,250 on the odometer, daily commuter. Anyone have any experience with this? And is it okay to ride if it produces drips in my garage?
    Jan 2012
    sonoma, ca
    Have you considered checking the coolant level?
    Apr 2016
    Dallas
    Quote Originally Posted by jlindh View Post
    Yes, but looks like I need to take the front part off, below the handle bars. I've never been able to see through or into that MAX - MIN "window" inside the glove box. Do you happen to know if you can top off with any sort of universal coolant or do I need the proper Agip kind?
    Clearwater, Fl
    How is the oil engine oil level? If the o-rings on the drain plug and oil filter are not being replaced at least every other oil change you will start having drips.
    As for coolant a 2009 should be ready for its fifth coolant flush and change. What coolant did you put in after the last coolant flush in 2017 red, yellow, green or blue? Does whats dripping have the same dye in it as the coolant?
    Brakes should also be ready for their fifth fluid flush and refill.
    Apr 2016
    Dallas
    Engine oil level looks full to me, of course I always wonder if I am supposed to screw the dipstick in all the way in order to check level. It sounds like I am a few rounds behind on some of these flushes and refills (mainly as I was arm-twisting an Aprilia motorcycle dealer near me to do maintenance and they always seemed a bit reluctant.) Brake fluid levels look correct so I'm thinking it must be coolant. Planning to remove front to add coolant, but I cannot tell the color since I can't ever seem to see anything on that MAX - MIN level in glovebox. If I am adding a 50/50 universal coolant, can I use any color?
    Clearwater, Fl
    You really need to look from underneath the bike to see how high up the leak is. A coolant leak will usually come from around the water pump weep hole which is above the oil drain and filter so if the leak is from above the oil drain/filter then look at the water pump and its hoses and if the leak is from higher than there its time to look higher up at the valve cover gasket and head gasket or possibly even the plug on the timing port, then you would also check the upper coolant hose connected to the thermostat and the thermostat housing and the coolant bleed valve.
    If you are not using a funnel when adding oil your drip could also be from oil being spilled when adding oil. The o-ring on the dipstick also wears out and you can get a drip from there too.
    The 2009 Scarabeo is a bit different from the bikes with Piaggio engines since it uses a Chinese built engine that has no oil cup/cup/sump bolted to the left side of the bike, has the oil fill and oil pump on the opposite side of the bike compared to the piaggio 200, 250 and 300cc engines and the thermostat on the left side of the head instead of on top of it.
    At this point I would not just add coolant but do a complete flush using a 50/50 mix of white vinegar/distilled water and do a complete inspection of the motor to determine exactly where the source of the leak is. It will be a lot more inconvenient to blow the engine than to vet this out before it becomes a major problem. Usually once the engine is cool you just turn the handlebars to the right and access the cap on the overflow tank to check the condition of the coolant using a bright light however on the 2009 Chinese 200 it may need to be checked from the radiator cap on the right side of the bike after turning the handlebars to the left.
    Also check that you do not have something in the under seat storage compartment that is leaking. Some have had some emergency fluids, Gator Aid, etc stored there start leaking and making drips and went crazy trying to find them when it was just something they had stored under the seat had sprung a leak and was dripping down over the engine.
    Apr 2016
    Dallas
    Thank you Rocky for this extraordinary amount of info and insight....that's why I come here! I have not attempted my own flush before but will give it a shot!
    Apr 2016
    Dallas
    Now it's a full blown coolant leak!!
    I have spoken with both the Aprilia dealer in Austin as well as Vespa Dallas but could use some owner opinions here. My temp gauge seems to be operating within the normal range, but I do now have a steady drip/pooling of green coolant underneath the center stand. I do believe the 2009 Scarabeo 200 to be primarily air cooled, so I am wondering if it is safe to continue commuting with it, even for just a few more days?
    Service manager at Vespa Dallas reports that the water pump is really an assembly that has several pieces which fit together. This makes me think the leak is coming from between two halves of the water pump (which has two hoses going into it, and it is on the right hand side, right near the oil dipstick tube. My bigger question for Rocky and others....can my coolant be getting into the oil reservoir (similar to a blown head gasket on a car) which means I have to quit using it immediately? I think I mentioned I am at 14,600 miles or so.
    Oct 2018
    athens
    There is a relief hole on the crankcase. That's why is dripping on the floor. So in essense if this hole doesn't get stuck then you have time before the other seal gets worn too.
    The safe move is to not touch anything and fix it asap although I (personally) wouldn't rush.
    Apr 2016
    Dallas
    Thank you for your thoughts on the relief hole, as I was unaware of it. It sounds like the relief hole is there by design and supposed to release coolant in certain conditions.
    Apr 2016
    Dallas
    Well I can attest to the fact that the '09 Scarabeo is in fact air cooled, perhaps primarily. I have been riding and leaking, mainly when I ride somewhere mid day and get lunch, then it pretty much just drips coolant the entire time. But the temp gauge stays right around the mid-point, reads a little hotter when sitting and idling at stoplights. I am topping off radiator weekly, basically dreading renting the trailer and taking it in for service.
    Oct 2018
    athens
    Such a huge loss is not good for the engine.
    Head gasket can burn easily.
    Also it may not be the relief hole if it drips while engine off.
    Apr 2016
    Dallas
    I took the front cover off last night and needed to top off the plastic expansion tank to bring the coolant level back up toward the MAX line. I did remove radiator cap and saw that there was coolant in there, at the base of the neck. I topped off just a bit, and wondered while I was doing it, if my temp gauge sensor is quite high up on the radiator and might not be giving me the actual coolant temp if the level drops below the sensor?
    Oct 2018
    athens
    The temp gauge is on the engine.
  1. Changing Hub Oil on 2009 Scarabeo 200
    By scarascoot in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 01-09-2012, 02:47 PM
  2. 2009 Scarabeo 200 (first oil change)
    By gti6cyl in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 10-26-2011, 11:27 AM
  3. Just bought a new 2009 Scarabeo 200
    By psijason in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 07-03-2011, 12:04 AM
  4. I let my 2008 Scarabeo 200 fall yesterday
    By cchamblee in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 04-13-2009, 11:37 AM
  5. Breaking in my new scarabeo 200
    By lakeerie4ever in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-09-2008, 08:25 AM
