Results 1 to 15 of 28
Thread: Bike wonít start
    Jul 2008
    The Hood, Ca. USA
    Bike wonít start
    Cranks fine. Ignition doesnít happen. Wth? Any suggestions?
    Dadsafrantic
    2015 Red Caponord #64
    Dec 2014
    Chelmsford, Essex, UK
    Any error codes or alarms? Have you tried with the side stand retracted? Is the fuel pump running? All fuses intact?
    When mine did this, I couldn't find any obvious faults so did a reset on the computers (pull out the master fuses for a few minutes) and all was well again. There is a quite a complex sequence of events that the bike runs through on start up so you might have to chase down the relays in sequence to check if one is going down.
    Jul 2008
    The Hood, Ca. USA
    Quote Originally Posted by AndyT View Post
    Thanks Andy. Side stand up. No error codes. I donít recall hearing the fuel pump but I had ear plugs in. I didnít have time to check the fuses as I was headed to work. Iíll start looking at fuses tonight. Which is the first to start with?
    Dadsafrantic
    Dec 2014
    Here's a grab from the owners manual that details the fuses. (Note; the last one has a typo and should have I not E)
Name:	Mana Fuse Box.jpg
    Jul 2008
    The Hood, Ca. USA
    Bike wonít start
    Cool thanks. I hope itís the problem. My normal 45 minute commute into San Francisco took 2 hours. It was kind of relaxing but as a one off. Weíll see how going home is.
    I was just thinking. My power outlet doesnít shut off with the ignition. Is it normal behavior?
    Dadsafrantic
    Dec 2014
    I was just thinking. My power outlet doesn’t shut off with the ignition. Is it normal behavior?
    Yeah, that's normal. I use mine to keep my phone charged with a USB adapter and realised it remained live as the tell tale light on the adapter stayed on after the ignition was switched off. I have to remember to unplug the adapter when the bike isn't being used. Interestingly the interior light is switched off with the ignition.
    Jul 2008
    The Hood, Ca. USA
    That didnít seem to work. Everything did reset though I think. Some noises down in front when I put the main fuses back in place. Is there a particular order to do? Iím putting the battery on a charger for a full charge in hopes that it would make a difference.
    Dadsafrantic
    Jul 2008
    The Hood, Ca. USA
    Btw going home was over 2 hours.
    Dadsafrantic
    Is the motor spinning over on the starter? If so pull a plug cap, stick a plug in it and earth it against the head then spin it over and check the spark. Is it fat and blue? If so it's likely good. That leaves fuel.
    Take the fuel filler off and see if you can see if there is fuel swirling around in the tank when the pump primes when the ignition is on. If it is I'd suspect that either the filter has blown off the hose or, if it's a two part plastic/aluminium filter it may of split at the seam between the two halves.
    Professional Goat Burster.
    Jul 2008
    The Hood, Ca. USA
    Thanks. Iíll check this out when I get home.
    Dadsafrantic
    Jul 2008
    The Hood, Ca. USA
    hey pete,
    i'm not sure if i see the filter in the schematics for the parts. there isn't a filter listed. i see a valve listed between the tank and the carbon cannister. (860138 Valve)
    i'm just trying to get prepared for when (if) i get home today. huge state inspection at work today. (health care)
    Dadsafrantic
    It’s probably not listed as a separate part in the schematic . I’ll look when I get home, I’m at the pub at the moment finding out the details of a manslaughter prosecution of a bloke in Bungendore and his mum! People killing other people doesn’t happen here!
    Jul 2008
    The Hood, Ca. USA
    Sorry to hear about that. Crazy world
    Dadsafrantic
    Jul 2008
    The Hood, Ca. USA
    Itís probably not listed as a separate part in the schematic . Iíll look when I get home, Iím at the pub at the moment finding out the details of a manslaughter prosecution of a bloke in Bungendore and his mum! People killing other people doesnít happen here!
    Okay I finally got a chance to look at both things you suggested. The spark is there. The fuel tank has no swirl when I key the ignition. All the fuses are intact as well. Iím wondering if itís the fuel pump. I donít hear anything like I hear on the caponord.
    Dadsafrantic
    When you turn on the key you should be able to hear the pump prime. It runs for about four seconds and then stops. Get your lug 'ole down close to the tank and then turn the ignition on. Pumps are fairly reliable. It would be more likely to be the relay I'd guess but it could be the pump itself.
    Pete
  1. Bike wont start
    By kaplano1 in forum RS125 Euro-archive
    Last Post: 10-25-2004, 06:50 AM
  2. Bike Wont Start!
    By Wee Jock in forum RS125 Euro-archive
    Last Post: 07-02-2004, 10:52 AM
  3. Bike wont start
    By barnesy1977 in forum RS125 Euro-archive
    Last Post: 11-15-2003, 08:41 AM
  4. Bike wont start HELP!!!!!
    By rob mcconnell in forum Pegaso 650 Cube and IE
    Last Post: 09-30-2003, 04:12 AM
  5. Bike wont start
    By r1y2k in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-19-2003, 11:44 AM
