Results 1 to 2 of 2
Thread: Pegaso 650 cube 2000 fuel pipes
    Jan 2019
    Croatia
    Hi, did anyone maybe preventively change the fuel pipes on pegaso 650 cube 1997-2000
    i try to find in local store pipe 5,5 x 10 mm but they don't have,
    what you suggested that i can put 5x10 or 6x10
    Sep 2015
    Fayence
    Just search somewhere like ebay for 5/16" ID fuel hose. It's readily available, even if your local shop doesn't stock inch sizes.
    If you must use metric, I'd go for the larger size.
    Does it need to be changed? If it's cracked or rock hard, then I say yes, but if it's still supple and looks to be in good condition, there shouldn't be any need. Inspect it first.
    Cheers... Paul
  1. Pegaso 650 cube 2000 ignition switch
    By Simao in forum Pegaso 650 Cube and IE
    Last Post: 03-02-2019, 09:01 AM
  2. 2000 Pegaso 650 Cube -
    By SmirnouF in forum Pegaso 650 Cube and IE
    Last Post: 06-18-2018, 09:52 AM
  3. New 2000 Pegaso 650 Cube Owner - Questions
    By Ralf_CT in forum Pegaso 650 Cube and IE
    Last Post: 07-24-2016, 09:54 AM
  4. [Pegaso] FREE! Pegaso 650 Cube Frame Parts - UK, London Area
    By sproggy in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 03-20-2013, 01:50 PM
  5. 2000 Pegaso 650 cube front sprocket install
    By jaeeoo in forum Pegaso 650 Cube and IE
    Last Post: 10-04-2012, 07:55 PM
