Results 1 to 5 of 5
Thread: Electrical problem :: No spark top cylinder
    apriliaforum Member BeeepSmoke's Avatar
    May 2010
    Rio de Janeiro, Brazil
    Top cylinder spark is faulting from time to time. Some days the bike starts perfectly and works fine, but suddenly (could take hours or minutes) the top cylinder spark fails . There is not a particular situation that drives the spark to fail, like engine hot or could.
    Two important information:
    - When the top cylinder is not sparking the tachometer does not work either. A soon as the top cylinder comes alive, the tachometer starts to work.
    - When the engine (working only with one cylinder) hits 4K RPM the top cylinder starts to work, but misfire like it was sparking in the wrong ignition time.
    Anyway.... In order to find the cause of problem Im playing the elimination game:
    - CDI changed (it was my first obvious choice). No success;
    - Spark plug changed. No success;
    - With the engine running, I plugged and unplugged all wires in order to find possible bad connection. No findings
    Next steps:
    - Change/Test the Control Unit (I think its not the case);
    - Change/Test Coil and spark plug cable;
    - Change/Test Pick-up.
    - Change/Test AC Generator
    - Change/Test Voltage regulator
    - Change/Test Battery and fuses (short circuit)
    Any thoughts??
    1999 Aprilia RS 250
    What man would be without his machines?
    Power without lightness and grace?
    Jun 2009
    Saint Petersburg, Florida
    it sounds like it could be a bad wire/connection if you ask me
    May 2010
    Today the bike started well, but after 5 minutes the top cylinder fails. it is getting worst... Ride this bike with only one cylinder is terrible, it moves like a RS 50... ;-( Tomorrow I will have time to check the rest of the electrical components.
    1999 Aprilia RS 250
    May 2010
    And the Oscar goes to top cylinder Pick-up...
    I tested/changed every single component on the list above. The pick-ups were the last components that I tested and changed. Its called Murphy's law. Lets see...
    During this week I will ride the bike naked in order to make sure everything is runnig well.
    1999 Aprilia RS 250
    Jun 2009
    loving the Tuono250
  1. electrical problem no dash board and no fuel pump
    By Resurrected SXV in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-13-2015, 08:27 AM
  2. Major problem, no spark, non running!! Hellpp !!!!
    By max.sr50 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 10-01-2013, 01:10 PM
  3. Help plz SR50 Carb M.H 50cc no spark strange problem
    By SAM-SR50 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-06-2012, 06:59 PM
  4. no spark 1 problem after another
    By f06352301 in forum RS50 Technical
    Last Post: 03-15-2008, 12:51 PM
  5. starter motor and no spark problem
    By Adidas in forum RS125 Euro-archive
    Last Post: 06-14-2007, 02:20 PM
