Results 1 to 11 of 11
Thread: What's the easiest way to remove the front wheel?
    Sep 2015
    VANCOUVER
    I don't have a front stand... Ceiling hoist? Jack underneath the sump somewhere? I need to change my rotors.
    apriliaforum Member KOCONUT's Avatar
    May 2013
    Huntington Beach, CA.
    I would suggest getting a front stand. You should be able to get one from vortex for not much money. You'll be cursing yourself if you drop your bike using some jury rigged setup. It will cost way more than a stand to fix potentially a cracked tank/bodywork/muffler etc.
    Sent from my Pixel 3 XL using Tapatalk
    Apr 2017
    Wrightwood, CA
    Do you have a rear stand or frame sliders? I have used a small jack with a small piece of 2x4 place under the bike. Lift it up, place the jack stands under the sliders and lower. You have to help balance the bike but its a solid fit. I've used it when i work on my forks. Ill post a pic here in a bit. Or just spend $70 on a front stand and make life a lot easier. Ill throw the bike up on stands for most work even oil changes.
    Apr 2017
    Wrightwood, CA
    Sep 2015
    VANCOUVER
    What's the best $70 stand? Would it be compatible with different bikes?
    Sep 2015
    VANCOUVER
    Quote Originally Posted by Number7s View Post
    What is the 2x4 touching on the bottom? I looked to something similar but couldn't really see how to not hit the header or oil tank...
    May 2013
    https://www.revzilla.com/motorcycle/...ead-lift-stand
    This is the one I use. There are cheaper options on Amazon and a standard front lift that will just lift the wheel off the ground are even cheaper. I'd recommend getting a headlift stand though, that way you can get all the weight off the front wheel and work on the front suspension. There are also cheapo headlift stands on Amazon but I've never used one and don't know the quality.
    apriliaforum expert FZ1JOE's Avatar
    Oct 2007
    Long Island NY
    I have the Pit Bull version of that , that's the way to go never mind ceiling hoists
    Oct 2014
    Oregon
    I just threw one together.. I removed the Plastic piece under the lower triple clamp,just not to damage it.. I use my welding jack stands for everything.. I have a good way to grab the bike overhead too.(safely) but a few minutes with my welder made it unnecessary.. The washer I made keeps the forks locked pretty well. The stand is pretty adjustable for height when the bike is on it.. Simple, and cheap for me..
    Sep 2015
    VANCOUVER
    Quote Originally Posted by KOCONUT View Post
    This is the one I use. There are cheaper options on Amazon and a standard front lift that will just lift the wheel off the ground are even cheaper. I'd recommend getting a headlift stand though, that way you can get all the weight off the front wheel and work on the front suspension. There are also cheapo headlift stands on Amazon but I've never used one and don't know the quality. Thanks, just ordered this one!
    Apr 2017
    Wrightwood, CA
    Quote Originally Posted by YVRFACTORY View Post
    The 2x4 rest on the header on oil tank. Not much pressure on it though, its just to keep the weight on the rear.
  1. easiest way to remove exhaust mid pipe? (prepping for oil pan replacement)
    By gittermoto in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 06-07-2018, 11:24 AM
  2. fuel pump install - what's the easiest way to get to it?
    By Solihull in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-25-2014, 05:17 PM
  3. easiest way to removed the sticker from the front fascia
    By Thom in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-20-2011, 08:11 AM
  4. what is the easiest way to change the oil?
    By 01Futuraman in forum RST1000 Futura (all years)
    Last Post: 09-20-2008, 05:49 AM
  5. what tools do i need to remove the flywheel
    By 01dabreoo in forum RS50 Technical
    Last Post: 05-16-2006, 07:35 AM
