Results 1 to 12 of 12
Thread: Sportcity has not spark
    May 2019
    Spain
    Hi guys i from spain and i have just bought aprilia sportcity 250 ie with no spark.
    I have changed:
    1:spark plug
    2:spark plug cable
    3:high voltage coil
    4:stator coil
    5: battery
    6:voltage regulator
    7: electrical harnes
    After that no spark so i changed trotel body(ecu) and works but just for 2 days them same problem.
    I am waiting for other ecu anybody had the same problem? Thabks
    Enviado desde mi iPhone utilizando Tapatalk
    Jun 2013
    croatia
    check the key code antenna, no code = no spark
    May 2019
    Spain
    Thabks but my sportcity has not anntena and has not coder key
    May 2019
    Spain
    I have received a new ecu and it worked one day and after that it fails again i dont know what i have to do
    May 2019
    Spain
    Hi my 250 sportcity neither antenna nor key code
    Jun 2013
    croatia
    take apart the mechanical and electrical part of the key lock, clean it well and try to override it in ON position so you can make sure that the keylock is not the probelm.
    Also a good idea is to take apart the emergancy on / off switch and render it dead to make sure that there are no shutoffs due to the switch.
    Check the wiering ground on the engine and try to attach a wire from the - on the battery to the engine and then to start the bike. Check the grounding terminal on ignition coil for a good ground and measure it to see if its faulty. Measure the impulse comming to the ignition coil if there is none check for the engines pickup sensor (sensor that gives a impulse when to fire the engine) its located near to the water pump. If ok when cranking it should show 0.6-1V if it dosnt produce any voltage you just found your problem.
    It seams that you have a small but nasty problem, try to render all switches dead that can shut off the engine then inspect the ignitin system like described.
    May 2019
    Spain
    Thanks so much, i have used the multimeter in order to check that i have 12v when i actovatw the keyswich so it works when i put to on the keyswich.
    Also i have meaasured the pickup senson and i have 2,3v like manual workshop says, grounding look like ok because i have check all negative points pf harness ans they are conected to the engine.
    Emergency switch and the switch who stop the enfine when motorbike go to the floor is ok also.
    I am getting craZy, i get to do obd2 diag and i found this faults
    I have to investigated and it says light efi error, i suspect that maybe i have a short xircuit inside of the dash board, i have opened him and i can not to find anything strange
    But i have a strange meassure that i dont like, i have 4,7VDC on ECU connector bettween pin 1 (which give EFI signal from ecu to dashboard)and ground, the strange is if i meassure this pin with +batery polimeter say 7,3VDC, is impossible that i have VDC meassuring between pin 1 with + and pin 1 with -?????
    Jun 2013
    croatia
    there must be a short circuit somewhere in the system, disconnect the dashbord and try again, also you can pull the tps connector of and try start the engine.
    If it runs the tps is faulty.
    May 2019
    Spain
    I have tried with the dashboard connector removed but the ecu which i have righ now is damaged so i am waiting for to receive a new one but my big dude is if it is normal the voltage that i have found on pin 1.
    May 2019
    Spain
    Tps is integrate om ECU so i can not disconect the ecu main conector (motorbike does not work)
    I changed all electrical wires so i think there os not a short circuit on wires, i think dashboard has a short inside and it is sending a short circuit inside ECU by pin 1
    If you have a look to the faults picture PO650
    Jun 2013
    croatia
    go to the dash and just pop the main connector and you are disconected from it
    May 2019
    Spain
    I have already done but i can not test again because ecu witch i have is broken again i am waiting for a new one and when she arrives i will check
  1. not sparking!
    By dellenty69 in forum RS50 Technical
    Last Post: 08-09-2007, 04:38 PM
  2. Ohlins fork compression adjustment has not "clicks"
    By hyperdrive in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-06-2007, 08:14 PM
  3. We bought our SXV yesterday...it still has not started!
    By RebeccaR in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 12-18-2006, 01:11 AM
  4. Not Sparking
    By Aprilia-rs50 in forum RS50 Technical
    Last Post: 07-08-2005, 11:52 AM
  5. Not sparking
    By Aprilia-rs50 in forum RS125 Euro-archive
    Last Post: 07-08-2005, 10:15 AM
