Results 1 to 6 of 6
Thread: Aprilia sportcity 125 2011 - no spark
    Jun 2019
    uk
    Hi guys, mi first post on this forum, very exciting.
    First of all thank you!
    right so secon sportcity i own i had a 2008 model, bought a 2011 model. A bit of gamble as i paid literally little but engine could not check engine was working as battery flat and was sitting for long.
    Main issue at the minute I cannot get spark, I have my other sportcity to check if parts are workign so this is of great help. Where I am at the minute:
    1 replaced battery
    2 engine spins freely
    3 new spark
    4 i have taken working coil from other sportcity and nothing
    5 coil fitted to other sportcity works
    5 all fuses fines
    where next:
    6 kill switch? would engine still be able to spin if kills switch is on, and therefore not getting spark?
    7 stator magneto etc as below?
    if so do i need a pulley, what size is it?
    any help would be massively appreciated as I literally do not know where to look.
    THANK YOU!
    Jun 2013
    croatia
    you have a crank but no spark situation
    There are multiple causes but often the bike is OK but the key code antenna is not, so when the antenna cant read the code from your key you will get that problem. So first try starting it with a nother key, then if it dosnt work check and test the antenna.
    Also sometimes the killswitch or the sidestand killswitch will produce the same issue (they get stuck in off position) unplugging them will let you figure out fast if they are the problem.
    Best of luck searching for the problem.
    Jun 2019
    uk
    Wow thank you so much:
    Sportcity cube 2011 cube is there a coded key and antenna?
    Where is it?
    Also I have one key only....
    Also is there a sudestand kills witch?
    Thank you so much....
    Jun 2013
    croatia
    Yes the 125cc engines have a keycode and a key antenna, its located around the ignition key lock (you will have to remove the knee plastic to access it). Often the antenna wil disconnect itself from vibrations or get damaged during service intervals if you are not avare of it and pull it.
    Yes if its a factory mounted sidestand it has a kill switch on it.
    May 2019
    Spain
    Sorry i have fail with the post, i have the same problem with sportcity 250 and i thouht that you answered to my post sorry
    Enviado desde mi iPhone utilizando Tapatalk
    Jun 2019
    uk
    hi guys can you point me where the antenna is? I cannot find any reference on the spare parts?
    or is maybe somewhere here:
    same thing for the stand sensor....no idea where to look as i have checked the stand and there is no wire sensor goign/coming from...
    thank you
  1. Looking at an Aprilia Sportcity 125 (2010)
    By Danilo in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-04-2015, 05:46 AM
  2. My Frankenstein Aprilia Sportcity 125 -Ruckus Hybrid build...
    By Hppowdercoating in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 06-27-2015, 11:27 AM
  3. Aprilia Sportcity 125 starting problem
    By solaria in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 01-13-2015, 06:02 PM
  4. WTB: rear seat cover cowl aprilia rs 125 2011 (UK)
    By Cutters77 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 02-08-2012, 01:43 PM
  5. aprilia Sportcity 125
    By -James- in forum Other Aprilia Models
    Last Post: 05-12-2010, 08:38 AM
