Results 1 to 13 of 13
Thread: Throttle Lock suggestions?
    apriliaforum prov-nov SchadDad's Avatar
    May 2019
    USA
    I have a 2 day ride coming up next month and am looking for a throttle lock/cruise control option for my 02 capo that isn't going to cost me an arm and a leg
    Sent from my SM-N960U using Tapatalk
    apriliaforum expert calgaryjeff's Avatar
    Dec 2003
    Gilbert AZ
    https://www.ebay.com/i/292068596047?...0aAhe0EALw_wcB
    16 years and still going strong.......
    Sent from my SM-G975U using Tapatalk
    2003 CapoNord
    1985 Honda VF1000R (gone to a new home)
    IBA #23204
    May 2019
    USA
    Does that require cutting my grips up though?
    Dec 2003
    Gilbert AZ
    Quote Originally Posted by SchadDad View Post
    Nope. It's about a 15 minute install. No cutting or modification needed.
    2003 CapoNord
    IBA #23204
    May 2019
    USA
    I'll give it a go. I think my minister has one of these on his Vulcan 88
    Dec 2003
    Gilbert AZ
    The basic premise is that it grips onto your throttle grip and when you flip the thumb switch it tightens the metal band around it, holding the throttle open in whatever position you set it at. It can be adjusted so you can make minor throttle setting adjustments as you go.......
    2003 CapoNord
    IBA #23204
    apriliaforum expert CapoMario's Avatar
    Apr 2010
    London, UK.
    I use one of these. Very simple and effective.
    https://www.dimecitycycles.com/7-8-g...e-control.html
    Sent from my Pixel XL using Tapatalk
    FoodReactions.Org
    Food Intolerance, Allergy & Adverse Reactions
    Bookmark it... you never know when you need it.
    Memoirs Photography
    Weddings, Portraits and Events - Beckenham, Bromley, London & Kent
    May 2019
    USA
    Quote Originally Posted by CapoMario View Post
    I am looking more for attach and forget. I've tried one of those fatigue rests that slips on the grip, but it's top much to fiddle with at 70mph
    Mar 2018
    California
    Wait, you didn't eliminate the rev limiter did you?
    May 2019
    USA
    What's that? Mama always told me doing 95 now and then is good for cleaning out the cobwebs
    May 2016
    I've been using this Scottoiler - https://www.scottoiler.com/product/s...ruise-control/
    It works! And even it's not a safest thing to do, I've managed to adjust it while riding with the help of the left hand.
    May 2019
    USA
    Quote Originally Posted by skvrnsk View Post
    That's the kind I don't want
    May 2019
    Nr Chichester, UK
    Highly recommend the Atlas black Top Kit - https://www.atlasthrottlelock.com/pr...nt=36907497473
    Purchased for a 440 mile trip to Wales and back mainly on UK dual carriageways and motorways. Went for this as had to return an Oxford plastic P shaped cruise control as this did not fit my oversize heated grips.
    Very expensive* but neat, well engineered, instinctive and efficient solution. Black finish blends in with controls, Top Kit does not interfere with heated grips. I use with the smallest friction pad.
    Click bottom button to set, top button to cancel.
    Easy to override when set but remember it is a throttle lock and not a cruise control. Provided you have postioned correctly for your favoured throttle position, requires one simple thumb click to cancel.
    * I purchased at the MCN London show in February, in addition to purchase price (110 iirc) got stung for currency charges on credit card. Hopefully as in USA you will get a bargain price!
  1. cruise control/throttle lock suggestions?
    By 01Futuraman in forum RST1000 Futura (all years)
    Last Post: 08-22-2010, 06:52 AM
  2. Throttle Lock...Success!! (3rd try)
    By beach pup in forum Aprilia and Piaggio 500cc
    Last Post: 04-24-2005, 05:44 PM
  3. throttle locks
    By acook in forum RST1000 Futura (all years)
    Last Post: 08-07-2003, 06:30 AM
  4. Throttle Lock?
    By gtoddh in forum SL1000 Falco Forum (all years)
    Last Post: 07-12-2003, 01:09 PM
  5. Throttle Lock?
    By gtoddh in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-07-2003, 10:31 PM
