Results 1 to 5 of 5
Thread: Mxv throttle body linkage help!
    Sep 2018
    Ireland
    I am changing my mxv throttle body linkage over from the round hole to the slot (previous owner had it this way).
    The arm after I took it out had a small Bush in the front hole (to front cyl throttle) but not one in the rear, the slot is also wider than the hole diameter.... Is seems very loose on the rear throttle body pin and the washer is just about big enough.... Question is should there be some of bush on this inside the slot?
    Sent from my FIG-LX1 using Tapatalk
    Sep 2018
    Ireland
    Well.... I tried installing the way it was, the closest I could get the the rear throttle body to start to open was when the front was at 14%...with the adjustment screw back right out.
    Decided to make a Bush for the slot. I used a Bush from a lever which was perfect fit both for the slot and pin on the throttle body and cut it down to size. The collar part was sufficiently thin that I could still install both washer and c clip.
    Was able to adjust the screw to get the required 10% throttle body opening.
    Feb 2009
    Tri-Cities, Washington
    Looks like it should be there.
    apriliaforum Junkie SXV_Jack's Avatar
    Jul 2018
    germania magna
    Have you the MXV Technical Course Manual ?
    Page 54 there is a notice about this conection arm.
    Sep 2018
    Ireland
    Yes I do have that manual, but it does no mention bushes.
    Without a Bush the washer and circlip are barely big enough to retain the arm, and there to much freeplay in the slot to achieve the rear throttle opening once the front had covered 10% of the tps value. The closest I could get was 14%
    With Bush I made installed I could adjust the balance to 10% as described in page 55.
  1. mxv throttle body linkage
    By chowderhead3 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-19-2014, 10:36 PM
  2. [Mille] WTB: Throttle body linkage piece
    By cew in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-17-2013, 07:57 PM
  3. Current thinking on asymmetric throttle body linkage?
    By swerver in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-14-2012, 10:25 PM
  4. Help with throttle body linkage
    By pacote in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 08-01-2012, 05:34 PM
  5. grub screws on throttle bodies linkages
    By fredgreen in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-09-2009, 12:42 AM
