Results 1 to 10 of 10
Thread: Gen2 fuel tank fit a gen1?
    Jun 2019
    Mount Vernon
    I just picked up a project 2000 RSV 1000 mille, The gas tank is corroded and Rusty and I needed to replace it as opposed to cleaning it. Would a 2004 and later gas tank fit on my motorcycle? Or am I limited to the 1998 to 2003 generation one fuel tanks? Any help is appreciated thank you
    May 2018
    Berlin
    No idea if a later tank will fit, i suspect not easily, but the later Gen1 Tanks are plastic and corrosion free. That said they do swell a little with the ethanol in the fuel. I left mine empty/drained over winter in a warm spot next to our heating system and it shrank back a little and fitted better come spring.
    Oct 2009
    think I have seen a falco tank fitted on a gen1 by konstantin on here of smaltmoto fame.
    Jan 2006
    I would be curious to know this as well. I am looking at a 1999 RSV with a dent in the tank and wondering if it might easier to replace with a gen 2 tank
    Jun 2019
    Mount Vernon
    From my research I think it will fit but you need to get some valance pieces and the seat might not fit perfectly. Also it appears to 2003 to 2005 tuono fuel tank will fit on a first generation RSV 1000 . I guess I wonít know until I try. I am going to see if I can get the bike running with this dirty fuel tank and might have to change out a few filters
    Jun 2019
    Mount Vernon
    I think the first picture you posted is a generation one bike? However my generation one looks different. It has two valance pieces that go along with the tank almost to the front. Maybe there were two different styles in the first generation? Come to think of it I donít know if my bike is a generation one. It has the Olens steering dampener and has brembo brakes front and rear. I thought these were only offered in the second generation? However my title says I have a 2000
    apriliaforum Member Bill R's Avatar
    Sep 2014
    Toronto, Canada
    Quote Originally Posted by 2000rsv1000 View Post
    I think the first picture you posted is a generation one bike? However my generation one looks different. It has two valance pieces that go along with the tank almost to the front. Maybe there were two different styles in the first generation? Come to think of it I don’t know if my bike is a generation one. It has the Olens steering dampener and has brembo brakes front and rear. I thought these were only offered in the second generation? However my title says I have a 2000
    In gen 1's there is a 98 to 2000 version like yours and 2001 to 2003 version.
    Tuono's 2003 to 05 are considered Gen 1 also, hence their tank is a straight swap on the later Gen 1
    Current Rides
    2 Black 1998 Suzuki TL 1000S's
    2001 Mille R/RR track bike - 08 engine, Amauri's big bore kit, 4 intake cams 108/112, 57mm Tb's, BGG 440cc injectors, Stefano's dual CF velocity stacks,
    Gabro's RP-RR chip, PC3, Evo air box spacer/fuel reg/ignition amp, modded Arrow 71100PR 2-1 exhaust, Brembo RCS masters, STM slipper, MPL slave,
    Dyno Jet quick shifter, Speedycom thumb brake, Woodcraft rearsets with Vortex pegs, 520-16/45, 180/60, Sharkskinz.
    Feb 2012
    Portland OR
    Here's a 2000 Mille which came w/ Brembos- you probably have a Factory if it has a steering dampner and carbon fenders/body work inserts. A gen 2 tank may or may not fit but will be missing the side covers that normally are fitted. Since yours is a "project" it may have components mixed from different years- Post a pic of it
    All aprilia Mille from 98-03, all RSVR 04-09, all Tuono, all Falco, all Futura, and all aprilia V4 come with Brembo brakes. The Factory moniker was not used till the 04 RSVR and applies to nothing before. All 98-2000 Mille came with a steering damper regardless of model. Ohlins on the 2000 R model.
    Sep 2017
    New York City
    Are you in Mount Vernon, NY? Would love to see the bike when you get it running or help if at all possible. Are you not able to find a tank for a 2000?
  1. Fuel tank fitting?
    By jimilivz in forum 2011-2012 Dorsoduro 1200
    Last Post: 01-27-2013, 04:12 PM
  2. Will a RS 125 2007-09 fuel tank fit a RS 125 2002
    By GradyPreece in forum General Motorcycle Talk
    Last Post: 12-24-2011, 08:46 AM
  3. Fitting PCIII: fuel tank removal needed?
    By Don R. in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 05-13-2009, 02:02 PM
  4. Fuel tank swap, will a 2001 fit on a 2000?
    By weirdsteve in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-11-2009, 12:28 PM
  5. Grr, fuel tank won't fit!
    By Aquator in forum ETV1000 CapoNord (2001-2007)
    Last Post: 05-11-2005, 05:16 PM
