Results 1 to 5 of 5
Thread: Startering problem
    Jul 2017
    AZ,TN,RI
    Startering problem
    Need some help from the collective...In the middle of a ride last weekend when I noticed my voltage dropping. Figured the battery gave up the ghost...installed new battery, as soon as I hook up the neg cable motor starts turning over, even without the key in the ignition. Whats the problem, a buddy suggested the rectifier..unhooked that..same deal. HELP!
    Thanx
    Oct 2012
    SW Idaho, USA
    if its cranking it means your starter solenoid it welded together. time for a new one or upgrade to the Motocraft style.
    if/when you fix that, the regulator/rectifiers are known to go out and cause charging issues. there are upgrades for that as well.
    If your idea of sport-touring is multi-position seats, cruise control and electrically-adjustable windshields, you’re probably not Italian and you don’t deserve a Futura. - Kevin Duke
    Jul 2017
    AZ,TN,RI
    Yep..it was the solenoid...never see one fail closed usually they stay open...thanx...I even had a spare
    Washington State USA
    Watch your starting voltage (you need a voltmeter on you dash) as welded solenoids tend to fry the starters. See the link about the $99 CanAm starter replacement.
    KB
    The underseat area on the RST1000 lends itself to the Ford solenoid upgrade covered in the sticky at the top of the forum.
    You should do it.
    KB
  1. Starting problems - Moto 6.5
    By prymaka in forum Professional Racing Discussion
    Last Post: 04-22-2019, 01:19 PM
  2. Starting problems? No way!
    By el2frij in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-10-2016, 01:33 AM
  3. RST starting problems
    By Neil in forum RST1000 Futura (all years)
    Last Post: 07-08-2003, 02:38 PM
  4. Starting Problems?
    By snwolff in forum SL1000 Falco Forum (all years)
    Last Post: 01-19-2003, 02:41 PM
  5. Starting problems
    By cbenson in forum Pegaso 650 Cube and IE
    Last Post: 07-08-2002, 10:12 AM
