Results 16 to 28 of 28
Thread: Track day tire pressure
    apriliaforum prov-nov Kenai's Avatar
    Jul 2016
    New York, N.Y.
    I had the images reviewed by Dave Moss who is a suspension setup and tire wear guru.
    Nov 2016
    Lincoln
    Quote Originally Posted by Kenai View Post
    Indeed he is! At least you have something to personally work towards next time out.
    We probably ought to have invoked Dave a little earlier:
    Starting with what you're already familiar with and extrapolating from there is just sensible, I'd say.
    And remember we're talking about road tyres that warm up quickly and operate at a cooler temperature anyway.
    2009 Shiver (White) | UK
    Aug 2015
    Dallas, TX
    well first track day complete.
    Already bumped to level 2 (out of levels 1,1.5,2, and 3) and scraping pegs.
    Thinking about getting a 190/60 for my next rear since I'm running the entire rear to the edge compared to the front.
    Also need to look at getting foot peg risers or stiffening suspension all the way around.
    Had a great time!
    Don't be a jerk... jerk
    2016 KTM 250 xc
    2013 KTM 350 xcf ---------------SOLD
    2011 Husqvarna 630 ------------SOLD
    2007 KTM Superduke 990-------SOLD
    2009 Dorsoduro 750
    2003 KLX 400R
    2009 YZ450 -----------------------SOLD
    2007 ZZR600 ----------------------SOLD
    2006 CBR600RR ------------------SOLD
    2009 Ninja 250 -------------------SOLD
    Aug 2015
    Dallas, TX
    oh yea.
    I ran 28r 30f cold. On the Metzeler m7rr. Never had an issue all day. Hooked up great!
    It was a coldish (for texas) day on the track too.
    2016 KTM 250 xc
    2009 Dorsoduro 750
    2003 KLX 400R
    apriliaforum expert maddad's Avatar
    AUS
    Great result ,remember the front will always wear different to the back .long as you had a good time it's the most fun I have had the track is a great place.
    Aug 2015
    Dallas, TX
    Next is Circuit of the Americas!
    2016 KTM 250 xc
    2009 Dorsoduro 750
    2003 KLX 400R
    Jul 2016
    New York, N.Y.
    A little advice on grinding foot pegs, check your suspension and learn how to lean off the bike. That will solve the peg grinding.
    Not so sure about the bigger tire.
    Nov 2016
    Lincoln
    Footpeg strike was one thing reviewers picked up on with this bike. Radical appears to be getting off the bike OK (given the ergo setup) from the pics he shared in the "what you done" thread. Hanging off even more has more benefit the heavier you are, or if you're already at MotoGP lean levels. Speaking generally, a smaller guy on a tall bike isn't going to have much impact (except, again, tipped right over), and the high handlebars make it pretty sketchy anyway.
    A quick fix for both the pegs and the tyre could come from adding more rear preload - do it a bit at a time and keep one eye on the steering feel. It's only marginal in absolute terms (a few mm at the pegs), but it should make a noticeable difference.
    Reducing tyre deformation can sometimes bring a bit of margin back, depending on the tyre. It's possible the lower tyre pressure hasn't helped in that regard.
    On the other hand, it might not even matter. If it feels OK banked over, then all's good. My old Z8s felt squirmy on the edge, and would go over, but that was more a result of the comparative lack of carcass stiffness.
    apriliaforum expert jay dub's Avatar
    Apr 2010
    OREGON
    Suspension will not help peg grinding..
    acab
    Aug 2015
    Dallas, TX
    stiffer suspension at a 50 lean angle will increase the peg clearance to the ground by ~ SIN(50) (marginal improvement). Now we just figure out if stiffening her up all round will make things better/worse/same for handling.
    Also about leaning off the bike. Instructor said I look great except I need to get my head to the side and lower more. Hips and legs looked fine.
    I definitely only had 1 ass cheek on the seat lol.
    2016 KTM 250 xc
    2009 Dorsoduro 750
    2003 KLX 400R
    Nov 2016
    Lincoln
    Cosine, surely? So yeah, halve it.
    Putting more weight on the front keeps the pegs higher more of the time, too (they're closer to the rear wheel) - hence my suggestion of adding rear preload only.
    Aug 2015
    Dallas, TX
    Quote Originally Posted by IndelibleInk View Post
    ummm it depends which angle ur taking? SIN = Opposite/hypotenuse. Relative to the road it's SIN. relative to bike up/down it's COSINE
    ANYWAYYY
    I think we can all agree peg risers would probably be the best option! haha
    Slight uphill left hand turn... the bike didn't want to turn as well. Kinda felt like maybe the front was pushing/plowing a bit. Maybe increasing rear preload would help a bit as well with that.
    I have 1 trackday under my belt. I'm a pro.
    2016 KTM 250 xc
    2009 Dorsoduro 750
    2003 KLX 400R
  13. #28
    Nov 2016
    Lincoln
    Cosine starts at 1 for zero angle, i.e. upright. So any vertical distance from the ground plane to a fixed point on the bike is reduced as per the cosine of the angle as the bike tips over. Still, even a few millimetres is not to be sniffed at, especially if it stays higher more of the time as well. This really is more for anyone else reading.
    It does sound like you could do with more weight on the front wheel, which is common for naked bikes in general. Adding rear preload tests that theory; if it works, consider raising the forks / dropping the clamps to a similar degree - then footpeg risers would indeed be useful.
    Others have done this already, so it's a common response to a handling need the bike presents in certain situations; i.e. track work. It'll just feel better on the road as well in all likelihood, more assured.
  1. Track day tire pressure?
    By ttraynor in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 07-31-2012, 02:00 AM
  2. Track day tire pressure recomendations?
    By Steve / AF1 Racing in forum Aprilia Privateer / Club Racing
    Last Post: 04-21-2005, 03:37 PM
  3. Futura Track Day Tires?
    By JeffC in forum RST1000 Futura (all years)
    Last Post: 03-24-2005, 03:46 PM
  4. track day tires
    By snoggin in forum RS250
    Last Post: 03-14-2004, 10:17 PM
  5. Track day tires
    By Smoke Eater in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-24-2003, 12:11 PM
