Results 1 to 7 of 7
Thread: Need a part number (2006 500GT)
    apriliaforum Member dleasman's Avatar
    Mar 2011
    Mankato, MN USA
    I need a part number... For the plastic cable stop for the hard pannier door (stops it from opening too far)
    It's a flexible plastic stem, maybe 6" long, with a loop on each end that hooks to the inside of the lid, and body of the pannier.
    Any chance ANYONE has a part list that would show this part?
    Clearwater, Fl
    You may have to call AF1 or contact Givi directly for those. I had on snap on one side of my top case and I have not been able to locate any parts listing showing it for sale so I plan on making the call too. The are a fragile consumable so I would think it reasonable that they be sold in common sizes based on length but...
    Mar 2011
    Mankato, MN USA
    Thanks for the tips.
    I was able to get a full parts diagram off the AF1 site, and save it. I had not found this document previously, but is now part of my Beo500GT docs collection.
    Unfortunately, there is minimal information in the parts list for the side cases.
    Giving was a great idea too, and I found this:
    https://tourandride.com/cases-and-ac...ps-pair-detail
    Exactly what I need!
    Clearwater, Fl
    Quote Originally Posted by dleasman View Post
    If you could measure them and let me know the length that would be great. Its been a few years since I have looked however I am not sure its a one size fits all situation and would be nice if it was.
    Mar 2011
    Mankato, MN USA
    The length is just over 10.5 inches, or about 270mm.
    Mar 2011
    Mankato, MN USA
    In the end, I was able to repair the one I had. I used an electronic lighter (uses an arch of energy), and was able to "weld" it back together. So far, it's holding just fine.
    Clearwater, Fl
    Congratulations - You were fortunate on that one. Perhaps I will break out my plastic welder and try again on mine. I recently put a separate air flow regulator on it that is much more accurate at low flow rates which has made it much easier to do delicate work.
  1. need a part number... if it exists.
    By fr0st in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 11-26-2017, 09:00 PM
  2. 2006 DiTech BBK Part numbers
    By veloracermike in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-22-2008, 11:24 AM
  3. Oem part numbers needed
    By Janky in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-05-2007, 10:22 AM
  4. Part Number Needed
    By scottch in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-23-2004, 10:21 AM
  5. Need help getting a part number ASAP...thanks
    By vpr80 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-02-2003, 07:59 PM
