Results 1 to 7 of 7
Thread: Difficulty selecting gears on downchange
    Nov 2018
    Lanarkshire, Scotland
    So I have a new issue which has only come up tonight.
    Lubed my chain earlier today and went out tonight - I was really enjoying a nice zoom around with my nicely tuned engine running strongly, when I noticed slowing down and changing through 3rd 2nd 1st , id shift gear and release the gear lever and then I could hear a click a second later.
    Later on at a standstill I was pressing the lever to shift down and it wasn’t shifting until I rolled the bike forward a bit.
    Im worried this is a selection lever problem in the box.
    My chain is very slack just now, going to order a new one tonight. Could this be anything to do with it? I might have stretched it more actually when I lubed it because I pushed quite firmly on it with a brush and turned the back wheel to clean it.
    apriliaforum Junkie ransamuels's Avatar
    St. Louis, Missouri, U.S.A.
    Not shifting when sitting still is normal. Having to roll a bit in order to make a gear change is normal.
    If your chain is loose and you cannot take up the slack with the adjusters then you need to remove a link. I don't think the chain needs to be replaced. Just cleaning and lubricating it would not cause it to "stretch". Remember to be careful and not over tighten the chain. You need to have enough slack to be able to move the chain at least 28-30 mm. If you don't do this you will damage the bearings and cause untold grief.
    1999 RS 50
    unknown brand 80 cc BBK cast iron
    LeoVince V6 pipe
    Dellorto Phbg 21 mm cs carb
    Oil pump deleted ... Premix 32:1 Motul 800 racing oil
    12:44 gearing
    Sava MC18 tires
    Nov 2018
    The bike wasn’t shifting into first when at a stop so that’s new , it’s always been fine. The clicking sound is a worry too. I can change down 6-5-4 as normal but 3-2-1 is not working as it should.
    I’ll need to check the oil level is ok. The bike smokes a lot on startup for a couple of mins, Like enough to be clouds floating across my garden. Blue smoke. Could this be gearbox oil? Bike doesn’t idle without throttle during this burning off period, once smoke clears it idles properly.
    I recently put a new clutch on it and with that and the new oil it made finding neutral much easier. Clutch is working smoothly and I don’t think there’s a problem there.
    1 - Is it bad practice to hold clutch in when rolling to a stop and click down through gears? As in bad for the box ?
    2 - Do I need a tool to join the new chain I’ve ordered? Got new sprockets with it, I wanted to gear my bike down a bit anyway.
    2010 TZR50 70cc airsal
    21mm CP
    Technigas ebox
    Nov 2017
    Slovenia
    2. I changed my chain set today,you dont need special tools if you ordered correct lenght(numbers of links).
    Jun 2009
    Saint Petersburg, Florida
    i would pull it apart and see...
    Nov 2018
    Quote Originally Posted by mattology View Post
    That job would be a first for me. Big job eek.
    21mm CP
    Technigas ebox
    Jun 2009
    it's not that bad, i promise. you will need a couple of things that you may or may not have handy:
    1: case splitter
    2: an oven you're allowed to put your cases in
    3: a freezer you're allowed to put your crankshaft in
  1. Stock gearing on tulip red Tuono?
    By Phil3 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 10-14-2005, 12:35 PM
  2. Gearing on RSVR
    By formerRR in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-01-2005, 02:37 PM
  3. Reverse gear on Tuono
    By muratd in forum General Motorcycle Talk
    Last Post: 08-26-2005, 01:41 PM
  4. Top speed in first gear on a 2000 RSV?
    By RSV_Ecosse in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-20-2004, 05:55 AM
  5. Best gearing on the rs
    By badboy04 in forum RS125 Euro-archive
    Last Post: 07-07-2004, 03:03 PM
