Results 16 to 30 of 35
Thread: Pig dead
    Jul 2011
    shropshire UK
    you need to get the two bits married up in the right position, takes a bit of taking apart, working out how the key will operate the switch and then put back together in the correct order. It can take a few goes to get it right!
    “If it looks like a duck, and quacks like a duck, we have at least to consider the possibility that we have a small aquatic bird of the family anatidae on our hands.” Douglas Adams
    apriliaforum expert robbie7334's Avatar
    Mar 2010
    South Wales uk
    Quote Originally Posted by dobbi View Post
    I have tried every position even had the ignition coming on in the off position.
    Doing my head in I was thinking in my last post if I can just get the bike to work the electrician will sort for me regards Robbie
    apriliaforum expert ytc1's Avatar
    May 2010
    St Helens, UK
    Quote Originally Posted by robbie7334 View Post
    Ah, this sounds like s buggered switch. I fixed mine once with a bit of tie clip pushed in lower section to force connection.
    The next time it went I stripped it down. Stuck the key in the switch (for sensor) and turned on ignition with a screwdriver.
    Sent from my Moto G (5S) using Tapatalk
    A square Peg in a round hole - http://ytc1.blogspot.co.uk/
    Mar 2010
    South Wales uk
    Quote Originally Posted by ytc1 View Post
    Do you think it will work what I suggested in last post ? Regards Robbie
    May 2010
    St Helens, UK
    http://ytc1.blogspot.com/2016/10/semi-retired.html?m=1
    Something like this
    Mar 2010
    South Wales uk
    Something like this
    Ignition sorted just clutch cable to change should be all good to go
    May 2010
    St Helens, UK
    That is far neater than any of my efforts :-)
    Clutch cable, bloody PITA. I hate doing them, even when I have a pre-routed one to use.
    Mar 2010
    South Wales uk
    While I was doing this little job noticed that the clutch cable was a little frayed close to the lever.
    Normally wouldn’t bother me but around 600 miles ensuing think it’s best to renew the cable.
    I have a brand new one in the shed so I will replace it over the weekend.
    Not looking forward to the job tank off and a lot of fiddling around regards Robbie
    Jul 2011
    shropshire UK
    Its an easy job Rob. Just make sure you follow the routing of the old cable by dismantelling it from the top first. the you can follow the cable through the correct routing back to the clutch. When I did mine it was like a new bike!
    Mar 2010
    South Wales uk
    All done don’t think that cable would make the journey? Regards Robbie
    Jul 2011
    shropshire UK
    I can beat that!
    May 2010
    St Helens, UK
    I can beat that!
    Need to borrow a Peg?
    Jul 2011
    shropshire UK
    That was a few years back!
    I knew something was wrong because I was adjusting my clutch every week!
    At the moment everything is working tickety boo. However, I'm coming with extensive spares and a decent toolkit because I just have a feeling......!
    I've even cleaned the bloodly thing!
    May 2010
    St Helens, UK
    I've not got the panniers on, so no magic box of spares. Hopefully no one will rear end any one else.
    apriliaforum expert tom-cat's Avatar
    Oct 2009
    Gisburn, Lancashire.
    Dobbi has had his account hacked!!!!
    "If it ain't broke, keep fixing it until it is."
  1. Newbie SR50 battery dead...
    By unchi2 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 09-15-2003, 06:22 PM
  2. Speedometer Dead - Common problem/easy fix?
    By Litarka in forum Aprilia and Piaggio 500cc
    Last Post: 07-23-2003, 11:00 AM
  3. "TOO MUCH DAMN NOISE" - Mr. Pig
    By JoshkDry in forum RS50 Technical
    Last Post: 05-01-2003, 06:36 PM
  4. Dead starter - Expensive?
    By Sach in forum Pegaso 650 Cube and IE
    Last Post: 04-24-2003, 11:18 AM
  5. Dead Peg...
    By Usul in forum Pegaso 650 Cube and IE
    Last Post: 02-19-2003, 06:04 PM
