Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Pig dead
    apriliaforum expert robbie7334's Avatar
    Mar 2010
    South Wales uk
    Pig dead
    Pig dead turned the ignition on and nothing on the display?
    Only thing on the screen is the flashing red alarm thingy.
    Loose wires or shorting of some sort.
    Luckily it didnít happen next weekend hopefully get it sorted soon regards Robbie
    apriliaforum expert ytc1's Avatar
    May 2010
    St Helens, UK
    Quote Originally Posted by robbie7334 View Post
    Just battery flat.
    Happens all the time if left for a couple of weeks.
    Sent from my Moto G (5S) using Tapatalk
    A square Peg in a round hole - http://ytc1.blogspot.co.uk/
    Mar 2010
    South Wales uk
    Quote Originally Posted by ytc1 View Post
    Just battery flat.
    Hi Bruce use it every day did notice when I turned the bars to right hand lock every returned to the display and the bike started.
    Straightened the bars and the bike cut out .
    But now it wonít do nothing at all.
    So Iím thinking wiring issues
    May 2010
    St Helens, UK
    Ignition wire time.
    Mar 2010
    South Wales uk
    Pig dead
    Ignition wire time.
    how do you separate this unit to get at the wires please
    Sent from my iPhone using Tapatalk its definitely the problem when I push the upwards the display engages
    May 2010
    St Helens, UK
    Ha, I've had hours of fun with that one.
    Press the tabs in, while twisting a small screwdriver in the gap between. Sort of.
    May 2010
    St Helens, UK
    You are after the very bottom bit, I reckon mine are a bit buggered now, but then I don't care :-)
    Mar 2010
    South Wales uk
    Ok thanks will have a go regards Robbie
    Mar 2010
    South Wales uk
    oh my god what a ball ache to split that unit!!
    Will have to get the soldering iron out.
    Never used one before
    May 2010
    St Helens, UK
    Yep, but once loose, easier the next time :-)
    Mar 2010
    South Wales uk
    Hope there wonít be a next time
    apriliaforum expert tom-cat's Avatar
    Oct 2009
    Gisburn, Lancashire.
    In preparation for your visit to the wild North, I'm planning a route comprising of only right turns to allow your bike to continue running!
    "If it ain't broke, keep fixing it until it is."
    May 2010
    St Helens, UK
    Depends on the person soldering.:-)
    I've had two unrelated issues that required it being removed.
    Jul 2011
    shropshire UK
    Yep it needs a really good hot solder, none of this tacking it on rubbish!
    its worth cable tying the ignition wire on to the fork stansion when you put it back togeteher this stops any movement of the wire being transfered to down the wire to the solder.
    ďIf it looks like a duck, and quacks like a duck, we have at least to consider the possibility that we have a small aquatic bird of the family anatidae on our hands.Ē Douglas Adams
    Mar 2010
    South Wales uk
    Soldered the wire back in position.
    Refitted the switch and nothing.
    Dismantled it again turned the switch with a screw driver then ignition comes on ?
    Tried again it works in a certain position that holes on the bracket don’t marry with the fixing location??
    I have been Fannying about for ages with no luck.
    I noticed if you short the 2 wires without the key in the ignition it asks for a code on the display.
    However if you short the wires with the key in the on position the display works as normal
    so I'm thinking if I fit a simple on/off switch to the 2 wires as a temporary measure would this work??regards Robbie
  1. Newbie SR50 battery dead...
    By unchi2 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 09-15-2003, 06:22 PM
  2. Speedometer Dead - Common problem/easy fix?
    By Litarka in forum Aprilia and Piaggio 500cc
    Last Post: 07-23-2003, 11:00 AM
  3. "TOO MUCH DAMN NOISE" - Mr. Pig
    By JoshkDry in forum RS50 Technical
    Last Post: 05-01-2003, 06:36 PM
  4. Dead starter - Expensive?
    By Sach in forum Pegaso 650 Cube and IE
    Last Post: 04-24-2003, 11:18 AM
  5. Dead Peg...
    By Usul in forum Pegaso 650 Cube and IE
    Last Post: 02-19-2003, 06:04 PM
