Results 1 to 2 of 2
Thread: Spark Plugs
    Oct 2012
    Norfolk, VA, USA
    Spark Plugs
    Confident enough to do an oil change but smart enough not to do the drive belt... So question is: What spark plug types are you guys using for a 2011 Mana GT and is it an easy swap, do they come pregapped, or is it like rocket science?
    Nov 2018
    Sydney Australia
    Well Timnizza I am also new to the Mana GT and from what I have read here when it comes to doing the gearbox belt change you are better off letting someone else do that for you unless you have all the proper tools and computer program to reset the bike onboard computer. As for the spark plugs well the back two you can get to easily but the front two looks like you need to pull the radiator off just to get to them as for the gap they should be just fine right out of the box.. So that only leaves you with doing a oil and oil filter change and changing the tires and adjusting the chain and maybe new sprockets when they wear out as everything else looks to me like a shop job..
  1. Spark Plugs
    By redfalco in forum SL1000 Falco Forum (all years)
    Last Post: 10-02-2013, 01:51 PM
  2. change spark plugs
    By davedowling in forum RST1000 Futura (all years)
    Last Post: 06-13-2003, 03:54 AM
  3. Spark Plug Choice
    By ventusct in forum Pegaso 650 Cube and IE
    Last Post: 11-25-2002, 06:28 PM
  4. What's the spark plug gap is??
    By Jeremy Rawcliffe in forum Pegaso 650 Cube and IE
    Last Post: 07-15-2002, 01:28 PM
  5. spark plugs blackened
    By joeyeo in forum Pegaso 650 Cube and IE
    Last Post: 06-05-2002, 04:55 PM
