Results 1 to 10 of 10
Thread: Small screw lodged in my breather hose?
    Dec 2018
    Georgia
    So I was in the middle of doing the AF1 Racing breather reroute on my ‘09 SXV 550 when I removed the breather hose going to this small nipple behind gear shift and found a screw lodged in the hose? My bike has had really bad issues with oil getting in the air box, more so than I think should be normal. Why would this screw be in there? Could this have been causing my issue because it wasn’t venting properly?
    Feb 2009
    Tri-Cities, Washington
    That was somebodies method of blocking off that return line. Blocking it would not contribute to oil getting to the airbox, but actually is done by some to prevent it. The VDB models were deleted by the factory.
    Dec 2018
    Georgia
    Okay I’m replacing these lines altogether, should I just continue with the AF1 kit or should I maybe block that off?
    Feb 2009
    Many different opinions on here, but I’d just block it off as long as the full sized tank vent is still used.
    Nov 2008
    Western Australia
    *shakes head*
    There is nothing wrong with the original breather system...
    That hose allows oil that gets into the air box from the oil tank breather to drain back into the system..
    Sep 2016
    Norway
    With correct amounts of oil, I've never had oil in my filter box. Not once!
    Dec 2018
    Georgia
    Do you check the oil level with the bike running or the bike off because I’ve read to do it both ways from aprilia themselves so I’m not really sure which is true.
    Jun 2013
    Toronto, Canada
    Quote Originally Posted by Killian665 View Post
    It's about the same within a couple minutes of shutting off the motor. On my bike the oil level barely drops after an hour. Others drop more quickly. I actually came on the forum today to figure out which valve controls that.
    Jun 2013
    Toronto, Canada
    Oh, and he bike must be fully warmed up or you might get a low reading if the scavenge pump hasn't sucked up all the oil from the sump into the tank.
    Dec 2018
    Georgia
    Right I’ve always let it run like 5-6 minutes then checked it or checked it after a 10 min ride but the bike was always off then I read some bulletin from aprilia that said it had to be running. Didn’t know if it made a difference or not.
  1. Sludge in my air hose?
    By Wulffez in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-08-2008, 09:21 AM
  2. Rear Brake Usage - Anyone In My Camp???
    By angrybobr1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-27-2003, 07:49 PM
  3. 4.7 and 7grm rollers in my variator
    By stevodel in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-24-2003, 08:25 AM
  4. What gears should i put in my scooter?
    By laz224 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-27-2003, 09:50 AM
  5. Driving in my Aprilia sr50 DITECH
    By DITECH rider in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 12-14-2002, 05:24 PM
