Results 1 to 11 of 11
Thread: Scarabeo Ditech 50 - Poor Performance at Higher Speeds
    Jun 2017
    RI
    History: 2005 Scarabeo Ditech was running perfectly last year. Went to start it after a long ride the previous day and it started, ran rough for a couple seconds then died. After troubleshooting the issue was determined to be low compression. This spring I bought and installed a Malossi 70cc BBK. Compression went from 60 to 90 psi. Performed a TPS reset. The scoot starts and runs well at low speeds. Above 30 the scoot hesitates and sounds weird, like its being starved. It doesn’t lose power it just won’t continue to increase speed. I checked air pressure while running, it fluctuates between 65 and 70 psi. Still need to gauge fuel pressure while underway.
    Known “issue” leaky air compressor: performed a leak test with gas and shop air pressurizing the outlet. It leaks, but it doesn't seem too bad. I cleaned the seal between the orifice and the body but the leak remains…
    Does anyone have a guess as to what the problem is? I cleaned the injectors in an ultrasonic bath last year, but should I remove the reinspect? Could the leaky air compressor be the culprit? Thoughts???
    Jun 2017
    RI
    Noname - I read and attempted to perform CPR on air compressor however it didn't appear to help. I went on a long ride today with the goal of pinpointing the issue. I'd interested in feedback based on the below observations:
    • There are no ECU error codes
    • After first starting scooter and while idling it hiccups periodically (mid 60’s psi air, 100psi fuel)
    • The scoot runs very smoothly in the lower/mid rpm range when gently throttling (75psi air, 110psi fuel)
    • When hard throttling the scoot while accelerate well for a short period of time before it begins to experience serious backfiring and frequent SLOP (as low as 62psi air, 100psi fuel)
    • When full throttle after gently accelerating scoot maxes at 40mph and experience less intense backfiring/SLOP but can’t hit old max of 45mph (65psi air, 105psi fuel)
    • When at idle after riding air pressure will build and reach around 73psi
    If replacing the air compressor is the fix, what are your thoughts on the hs tuning air compressor?
    Thanks so much
    Jun 2017
    RI
    Almost forgot, but I was thinking of replacing the sparkplug even thoughts it seems fine (a little sooty but fully operational). Figured why not considering the scoot is about to be back on the road, fingers crossed. Mind confirming that NGK (6914) ZMR7AP Laser Platinum Spark Plug gapped to .040” is the best option for the scoot?
    apriliaforum Junkie lenko223's Avatar
    Oct 2009
    Zemun, Serbia, EU
    Did you check the fuel pump?
    APRILIA SR 50 DiTech Morini 2003;
    ECU De-Restricted,
    Champion RG6YC
    Leo-Vince ZX De-Restricted pipe,
    Stage 6 strong (red)springs,
    polini 5,5gr rollers,
    Malossi Red contra spring
    Vario: Polini
    Air box Malossi red sponge
    top Speed 110 kmh
    side foot - Buzzeti
    15W blue bulb
    a higher degree of reparation of fuel pumps
    Jun 2017
    RI
    lenko - I took the scoot for a ride with gauges monitoring air and fuel pressure. Results were provided above. I'm not familiar enough with the system to know what pressures I should see. Ideally, I'm looking for feedback as to if the measurements look good/bad. I also don't fully grasp the relationship between fuel and air pressure and how to discriminate which piece of hardware might be faulty when pressure is outside of the expected.
    Jun 2017
    RI
    Was out for another ride and scoot broke down. Lost all fuel pressure. The fuel pump is getting power and spins but no pressure. The pump was bought new last year and I replaced plastic connecting rod with aluminum rod... I'll open up sometime tomorrow to diagnose, but getting ready to give up on the scoot all together...
    Mar 2019
    Hungary
    if u want to replace aircompressor then buy from hs tuning .those guys like hgt real ditech guru.most failure parts are fuel pump and fuel pressure regulator.
    ecu reset do as follow :
    1. ignition off, throttle full open
    2. ignition on,throttle close
    Oct 2009
    Zemun, Serbia, EU
    Another fuel pump...
    ECU De-Restricted,
    Champion RG6YC
    Vario: Polini
    top Speed 110 kmh
    side foot - Buzzeti
    15W blue bulb
    Jenison, Michigan
    I may be late to the party, but there's also a check ball in the outlet fitting on the fuel pump. If it gets stuck, it will have a real hard time building and holding pressure while it runs(100psi seems kind of low, I'm running 118 psi at idle and stock on the SR is 115 psi I believe. Also, I hope you put fresh gas in it?
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Yasuni R
    Malossi VL 13
    Ecu De-restricted 2.8.0
    6.75g (7&6.5 mixed) Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Oct 2009
    Zemun, Serbia, EU
    Yes, this ball dictates the work of the pump ... they can be deformed and rusted...
    ECU De-Restricted,
    Champion RG6YC
    Vario: Polini
    top Speed 110 kmh
    side foot - Buzzeti
    15W blue bulb
  1. Scarabeo ditech 50 not getting fuel
    By Ernestod in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-04-2007, 06:09 PM
  2. Scarabeo ditech 50 not getting fuel
    By Ernestod in forum Aprilia News and Product Discussion
  3. scarabeo ditech 50 won't start - clicking - no fuel?
    By AriesG in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-20-2006, 04:58 PM
  4. Mojito 50 poor performance
    By abciccan in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-15-2005, 02:36 PM
  5. Scarabeo Ditech 50
    By RVSCOOTER in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-29-2005, 11:16 PM
