Results 1 to 11 of 11
Thread: What is this piece called and or what it #?
    Aug 2017
    Napa CA
    Its the shroud that goes over the key ignition? Looked on parts fiche but canít find it
    2016 Piaggio BV 350
    2008 Yamaha WR 250
    Jun 2013
    croatia
    yes it goes over the ignition and has to be turned in to lock on the plastic
    Clearwater, Fl
    Its sold attached to the lock body and goes for around $5 if I am thinking about the correct part. I believe they have one universal replacement that fits many Piaggio/Vespa bikes as it originally was part #298581 then superseded to 1B002607 which has a smooth outer rim:
    https://www.af1racing.com/store/Scri...28ex+298581%29
    Jun 2016
    Florida
    trim ring
    Aug 2017
    Napa CA
    Thank all, this piece goes on the outside and snaps and twists locks in place. The picture piece fits behind the plastic. Anyone know the item code for the outer trim ring piece?
    2016 Piaggio BV 350
    2008 Yamaha WR 250
    Clearwater, Fl
    Hey Fast - I took the liberty of reaching out to Ed at AF1 and he says that part is not found on the BV350's he has in inventory however they are all older models. If you could provide the VIN number he would be happy to research it for you.
    Aug 2017
    Napa CA
    Rocky, thanks for the leg work. this piece is off a 08 Scabby, not my BV 350.
    2016 Piaggio BV 350
    2008 Yamaha WR 250
    Aug 2017
    Napa CA
    I emailed Ed to see if he could find it for the scabby
    2016 Piaggio BV 350
    2008 Yamaha WR 250
    Clearwater, Fl
    Quote Originally Posted by FastCletus View Post
    Ok then that would be for the Scarabeo 200?
    Aug 2017
    Napa CA
    Yes sir.
    2016 Piaggio BV 350
    2008 Yamaha WR 250
    Clearwater, Fl
    Please let is know what Ed is able to dig up for you.
  1. What is this do-hicky and what does it do?
    By Barry Sheen in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-27-2016, 04:23 PM
  2. What is this 'Intake Restrictor', And how is it removed.. and why...
    By Topsie in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-16-2015, 06:24 AM
  3. Is this guy a scammer or just lazy?
    Last Post: 04-28-2013, 07:47 PM
  4. is this off a rs125 or a 50
    By adds_isard in forum RS125 Euro-archive
    Last Post: 12-09-2006, 09:17 AM
  5. Is this one of us or have the AZ guys seen it?
    By calgaryjeff in forum ETV1000 CapoNord (2001-2007)
    Last Post: 11-15-2006, 04:35 PM
