Results 1 to 15 of 16
Thread: 2002 Aprilia Mille R track/street many upgrades!! SOCAL
    apriliaforum Junkie CHAPlain's Avatar
    Jun 2013
    sw USA
    Feedback Score
    0
    Lightbulb 2002 Aprilia Mille R track/street many upgrades!! SOCAL
    PRICE: $4,500 with a fresh prep.
    MILEAGE: 16.3k
    Can arrange delivery to outlying areas.
    Trying to buy a home so need to pad the bank account a little more so one of the bikes needs to go. Unfortunately the Ape pulled the short straw. Bought this bike out of Texas off of here a number of year back, then went through the entire bike and made numerus upgrades along the way. Had a lot of fun weekends on it between a few long distance road trips, trackdays and canyon days. Bike is a solid performer and is setup as a camillion track-day/street bike. Plug-n-play LED light bar comes off as does the entire rear tail for track days or run it with the 2003 tail with carbon fiber pillion and KC HiLites LED's for the street. Nothing on this bike was hacked together, it is all done top shelf.
    ><> 2002 Aprilia SPA RSV Mille R <><
    Vin #: ZD4RPU0142S000145
    Engine #: Rotax V99ORP 955192
    >>Body<<
    • Body: Shark Skin full race body
    • Carbon Fiber: exhaust hangers, finders, dash cover, and rear cowl lid
    • Custom paint and pin striping by Richard Knight
    • Street tail: 2003 tail with LED lights
    • KCHiLites LED lights (removable light bar)
    • LED front turn signals
    • quick release seat
    • double-bubble windscreen
    >>ENGINE & TRANSMISSION<<
    • Engine Management: Power Commander 3 902-410 (usb)
      • Attack Racing dyno tune max hp=115.5, max tq=72.4
      • Valves adjusted by Amauri Nunes
    • Thermostat: 65c #8102614
    • Aprilia Low Temp Thermal Switch -#8112677
    • Evoluzione airbox with short aluminum velocity stacks
    • Early 2000-01 snorkel
    • Ackrapovic SBK Racing dual exhaust with matching eprong
    • Yoyodine slipper clutch
    • Clutch slave cylinder: Oberon Performance
    • Yoyodine/Euro Racing throttle
    • Tank full of fuel foam
    >>CHASSIS & SUSPENSION<<
    • Front Ohlin rebuilt by: Andy at Catalyst Reaction Suspension in Orange CA 8/2015 @ 11.4k
    • Rear Ohlin shock
    >>WHEELS, RUBBER & BRAKES<<
    • Front wheel: OZ 17"x3.5
    • Rear wheel: OZ 17"x6.0
    • Tires: Michelin Power Road IV
    • Front tire dimensions: 120/70-ZR17stock.
    • Rear tire dimensions: 190/50-ZR17stock.
    • Front brake master: new Brembo model for 2004-09 Aprilia RSVR 1000 with dash 2 lines @11.4k miles
    • Rear brake master: new Brembo model 11.4k miles
    • Pads: Galfery sintered g1375 @ 10k
    >>CONSTROLS<<
    • Woodcraft clip-ons (reservoir mounts, bar ends) (have stock)
    • Woodcraft bar-ends notched for mirros
    • CRG folding bar-end mirrors
    • Woodcraft rearsets w/ gp shift
    • Front brake master: new Brembo from 2004-2009 Aprilia RSVR 1000 with dash-2 braided line 11.4k miles
    • Clutch master cyl: new Brembo from 2004-09 Aprilia RSVR 1000 w braided line @14.1k
    • Clutch slave cylinder: Oberon Performance rebuilt @14.1k
    • AVS short levers and mounts
    >>ELECTRICAL<<
    • Battery: Shorai Lithium Battery new
    • Regulator: Shindengen MOSFET FH012A used on late (06+) Yamaha FJR, 07+ Yamaha R1 1D7-81960-00-00.
    • Starter Solenoid: Yamaha part # 4KD-81940-00-00 $40
    • Shindengen MOSFET FH012A used on the late (06+) Yamaha FJR, 07+ Yamaha R1 1D7-81960-00-00.
    • Ricks Motorsport Electric Stator PU21120243- $145 af1
    • Dash resoddered for LED turn signals
    • LED headlights, taillights and turnsignals
    • Entire bike rewired and nearly all connectors replaced with weather pack connectors.
    >>SERVICE/MAINTENANCE LOG<<
    • Bike will have fresh/new clutch, brake, oil, filter & battery on delivery! (if asking price is met)
    • Oil Filter: Aprilia OEM Oil Filter-part #0256187 (2.75 inch) -AP0256187
    • K&N Oil filter: KN-152
    • 14,500 changed oil/filter
    • 14,100 new clutch m/c and slave
    • 11,360 flushed water 74oz, Lucas water wetter 10oz
    • 11,360 fuel filter AP8102971
    • 11,360 Ft Brake fluid flush
    • 14,100 Rr Brake fluid flush
    • 14,100 Clutch fluid flush
    • 11,360 NGK R sparkplug DCPR9E x4
    • 11,360 Forks serviced
    • 14,100/11,360 Sprag clutch, & gear replaced with new ktm
    • 11,360 Head gasket frt & rr
    • 11,360 New air filter
    • 11,360 New front brake master cyl
    • 11,360 New rear brake master cyl
    • 11,360 New front brake lines to dash 2
    • 11,360 New Shorai Battery
    • 10,000 Frt Brake pads replaced
    • 8,500 Rr Brake pads
    • 8,500 Ft/Rr Tires replaced
    • 11,360 Amauri Nunes service:
      • Compression test 185 psi, both cylinders with cold engine
      • Cam timing and front to rear phasing is correct
      • Check for excessive play in camshaft drive mechanism
      • Valve clearances checked/adjusted as needed.
      • Flywheel key not damaged, replaced crank timing sensor and flywheel with timing triggers
      • Installed a test ECU and EPROM
      • Tested camshaft timing sensor per procedure in service manual
      • Swapped complete throttle bodies injection and measured fuel pump output pressure
      • Measured wiring continuity and connections between sensors and ECU connectors.
    >>The BAD<<
    • Paint on tank is bubbling and cracking from this wonderful California fuel.
    • slow speed lowside rubbed side fender
    • tire show even wear but probably could be replaced. These Michelin's wear like iron, but are about to age out?
    Jun 2013
    sw USA
    Feedback Score
    0
    more pics
Name:	Clyde (frt fender).jpg
    Jun 2013
    sw USA
    Feedback Score
    0
    More pics
    Sent from my SM-G960U using Tapatalk
    Jun 2013
    sw USA
    Feedback Score
    0
    Bump for price drop $4250. Such a bargain
    apriliaforum expert flossy's Avatar
    Jan 2012
    Seq/Qld Auzzieland
    Feedback Score
    0
    only ridden to church for morning services on sundays hey Chaplin, any nuns get to sit on it, that would hold the value higher, a ride made in heaven,
    she looks a beaut,
    Jun 2013
    sw USA
    Feedback Score
    0
    Did I mention most hardware has been swapped out for either TI or Aluminum? Also, fresh prep (Lucas Oil Synthetic racing oil, Lucas Oil Racing brake/clutch fluid, chain service. etc.)
    apriliaforum newb V2 Dave's Avatar
    Nov 2013
    West Coast SI New Zealand
    Feedback Score
    0
    Hate to say it... but she’s worth a lot more parted out.
    Jun 2013
    sw USA
    Feedback Score
    0
    Quote Originally Posted by V2 Dave View Post
    Nooooooooo say it ant' so! But I very well am going to start swapping out back to OEM and save for the good stuff for the next bike or sell separate.
    $4,300 OBO
    Jun 2013
    sw USA
    Feedback Score
    0
    A couple shots
    Jun 2013
    sw USA
    Feedback Score
    0
    Make offer or trade
    Jun 2013
    sw USA
    Feedback Score
    0
    Buy it someone or trade
    Jun 2013
    sw USA
    Feedback Score
    0
    Is it the price or the bike?
    apriliaforum expert stevieboy22's Avatar
    Apr 2015
    Illinois
    Feedback Score
    1 (100%)
    Personalized paint scheme?
    apriliaforum expert WileECoyote's Avatar
    Mar 2011
    East Tennessee
    Feedback Score
    2 (100%)
    Well sir, not knocking the bodywork but, is that all paint? I.E. no decals
    Sure is a pretty thing. GLWS
    ACME Race Team: Lead Mechanic/Chief Rider
    No wins, cant seem to get around them anvils. Falls from great heights tend to slow me down.
    2008 Ducati Hyper 1100
    Jun 2013
    sw USA
    Feedback Score
    0
    Quote Originally Posted by WileECoyote View Post
    The graphics: scallops, and flames are all handpainted/airbrush by ol time hotrod striper Bill Knight. Company logos are vinal.
  1. 2002 Aprilia Mille Track Bike $4000.00
    By mag in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 04-25-2015, 11:36 PM
  2. [Mille] 2002 Aprilia Mille Engine - $400
    By PumpinIron in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 11-29-2013, 12:40 PM
  3. 2002 Aprilia Mille R PARTS [BIKE IS SOLD]
    By TheGeek in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 04-20-2010, 05:12 PM
  4. 2002 Aprilia Mille R
    By TheGeek in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 04-17-2010, 07:14 PM
  5. f/s 2002 Aprilia mille RSV-R $6995
    By TITANMOTOR in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-27-2008, 07:26 PM
