Results 1 to 6 of 6
Thread: Internittant starting fault.
    Oct 2017
    Derbyshire. UK
    Intermittent starting fault.
    Rode the Mana to the MCN show the other week.
    Superb ride apart from one hiccup. An hour into my trip I stopped for fuel, after filling up I went through the usual start procedure, all powered up as normal, but on pressing the button, nothing, not even a click. I switched off the ignition waited a few seconds then tried again, this time the engine just turned over a few slow revolutions and managed to start.
    After another hours ride I arrived at my destination, switched off and then with a bit of trepidation restarted, all worked fine, the engine whipped over and burst into life as normal.
    This was a week ago and the problem has never resurfaced, starts on the button every time. I've checked the obvious things, battery is quite new, voltage is fine, terminals tight and clean, as its the earth. I even removed and checked the exposed terminal on the starter itself.
    The only thing I can think off is the starter solenoid by the side of the battery, maybe the internal contacts are corroded. I see there are a suspicious amount of them for sale on ebay, suggesting there is a demand for them .
    Has anyone had this problem, or indeed replaced the starter solenoid?
    Al.
    Jul 2017
    Kings Lynn
    I noticed a slower than normal turn over when starting at 8000 miles and I replaced the solenoid which cured the problem.
    Oct 2017
    Derbyshire. UK
    Cheers for that. There seems to be a vast difference in new price for the solenoid on ebay, ranging from less than 10 to 40. I wonder if some are Chinese copies.
    Al.
    Jul 2017
    Kings Lynn
    try and avoid the Chinese ones although some stuff from China is good, but do not buy a cheap one its the old adage you get what you pay for :-)
    Oct 2012
    Norfolk, VA, USA
    Starter Ground
    Check to see if there is corrosion on the starter ground that is bolted to the bottom of the engine. This was the problem I had with my mana.
    That isn't the ground. It's the power feed to the starter motor.
    Professional Goat Burster.
  1. Unusual nrg 50 purejet air? fuel? starting fault
    By chewin in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-26-2015, 11:29 PM
  2. bike wont start ,fault code po336
    By gazv4 in forum 2010-2019 RSV4 - All Variants
    Last Post: 05-06-2015, 03:15 PM
  3. Starting Issues - "NO START" fault code
    By matt2301 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-07-2014, 03:27 PM
  4. Starting fault
    By shadowblaster in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-28-2010, 12:20 PM
  5. Fault code cable conected. BIKE started !!!
    By roar32 in forum SL1000 Falco Forum (all years)
    Last Post: 04-17-2004, 02:59 PM
