Results 16 to 30 of 51
Thread: Bike isn't turning over, acting like wires are touching.
    May 2019
    USA
    This is under my seat. The solenoid setup was done by the guy before me. The solenoid itself is new, but seems to be sticking. The cross-wire fuse in the middle of the terminals is 30a. This all worked fine until the starter motor started going out I think. The battery is only a couple months old as well. Stator is brand new, just did that job with an oil change 2 weeks ago
    Also to clarify: where the red wire is going is the starter motor, correct?
    apriliaforum Junkie Kennibear's Avatar
    Washington State USA
    Yes.
    The mounting bolt on the left bottom of the starter is where I bolt the extra ground cable back to the battery negative terminal using the bolt in the parts photo and two copper washers top and bottom of the terminal so the bolt has a little crush. I cleaned the top of the starter mounting flange under the bolt with a Scotch Brite pad and some laquer thinner just before assembly so it has the best electrical contact.
    KB
    It looks like your cables are 4ga and that solenoid is kick ass if made in the USA. I would suspect the starter motor at this point or a corroded ground connection.
    My tool storage under the pillion is loaded with tools. Solenoid there not possible.
    KB
    Mar 2018
    California
    Do yourself a favor and disconnect that ground wire from the battery if you are working on the bike. A positive cable is an ugly thing to leave loose. If any tool completes the circuit between battery and any other part of the bike. Instant short. I use a pieces of foam rubber that I cut a slit into and always slide the battery cables into them right after I remove them from the battery.
    Negative off first, on last.
    May 2019
    USA
    Oh, I was in the process of disconnecting the terminals when I took that. They were only temporarily on while I was checking something
    Mar 2018
    California
    Looks like my starter is crispy too. I'll try a rewind service. Comes right after your initial post about this, comes in 3s so who is next?
    What do you mean -why do I have 2 ETV Caponords? I also have 2 arms, 2 ears, 2 legs, 2 eyes and 2 butt cheeks, I don't see the problem.
    Rick's Motosports has them and they are on eBay too. $250 ouch!
    KB
    #61-707
    KB
    May 2019
    USA
    Quote Originally Posted by Kennibear View Post
    KB
    If you goto parts giant they're 218 and free shipping
    Thanks!
    Just copied the link to my One Note Aprilia parts number page.
    I have it as a memory for the bike stuff.
    KB
    Mar 2018
    California
    Partsgiant must read the forum, now $249 there too.
    Mar 2018
    California
    It looks like the starter for the Bombardier and Can Am 990 Rotax is the same and about $150 less expensive too. Another option might be the starter for the BMW F650 which is also used for the Pegaso. If the current draw is the same it will probably work and be much less expensive.
    I doubt Aprilia spec'd a unique starter for the Capo, after all they didn't make the engine either.
    Dec 2007
    Cumbria
    Can Am starter fits, I bought one new in the UK. Spins up much faster as a bonus too.
    08 ETV 1000 Caponord
    NC705X DCT - The Blue Toad
    Honda PCX125 - White Lightning.
    CRF250L - LRP.
    May 2019
    USA
    Got a link for the specific can am or bmw one? I'm all for saving money
  1. Replies: 8
    Last Post: 09-11-2017, 03:08 PM
  2. Bike wont turn over after wash...please help
    By ledzep244 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-30-2009, 08:36 PM
  3. Troubleshooting bike that turns over but doesn't start
    By Vaprilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-22-2008, 01:01 PM
  4. Bike won't turn over or start
    By gmcenroe in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-08-2008, 02:12 PM
  5. Problem with bike starting.. cranks forever wont turn over.
    By ironminde in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-02-2007, 06:54 AM
