Results 1 to 3 of 3
Thread: Scarabeo rotax rear wheel play
    Jun 2017
    Riga
    I recently replaced my 99 scarabeo rotax rear wheel since the previous one had a crack. It was a used part since new ones are crazy expensive. Currently the rear wheel has a lot of play. I can move it easily. While driving it doesn't cause any wobble, but I think it probably is the reason my rear brakes are squealing quite a bit.
    Is any play acceptable for this model? Could maybe the shaft be worn out? Please let me know.
    Jun 2013
    croatia
    the shaft itself or the rim is worn out.
    Usualy there is no play in the wheels.
    Clearwater, Fl
    Is the wheel shifting on the shaft or is the shaft shifting in the gear box? You may be simply missing a spacer/washer on the wheel or perhaps needs to have the bearings changed in the gear case. Letting it go too long unattended could indeed lead to shaft or gear housing wear though so don't delay in correcting the situation.
  1. Scarabeo 200 Rear Wheel Removal
    By Chindog in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-05-2017, 06:46 AM
  2. 2007 SC 250 rear wheel play?
    By Alchymyst in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 06-18-2015, 11:47 AM
  3. rear wheel play - advice needed
    By paulphoenix in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 01-08-2015, 11:00 AM
  4. Rear wheel play / leeway when rotating
    By solpap in forum Aprilia and Piaggio 500cc
    Last Post: 02-21-2009, 10:44 AM
  5. scarabeo loose rear wheel
    By coreyshu in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-26-2004, 09:08 PM
