Results 1 to 8 of 8
Thread: Alternative Rear master cylinder
    Dec 2014
    Suffolk
    Has anyone done the mod to fit a ducati 848 rear master cyclinder in place of the OEM and maintained the OEM footpegs? If so do you have any photo's and were there any issues with the orignal brake plunger?
    apriliaforum expert tmtuono's Avatar
    SoCal
    I replaced mine with a BMW unit. The BMW unit was slightly smaller diameter and had a pin on the piston that limited piston travel. I'm assuming the pin was to limit volume and consequently max pressure. Anyway, after some measuring and figuring piston travel volume I trimmed the pin to give the same volume of fluid moved as the stock unit. The goal was to move the same amount of fluid but under higher pressure (smaller diameter piston). That was several years ago the the system works as expected. Don't know the specs for the Ducati cylinder. Also don't remember the exact specs for the Aprilia or BMW piston size but they're around here somewhere.
    see ya later,
    tony
    '03 Tuono Magnet Grey
    '05 BMW BCR '07 R1200S '78 R100
    But Officer, I got here as fast as I could.
    apriliaforum expert madart's Avatar
    Aug 2011
    Australia
    I replaced the rear caliper with a Ducati one. There is no difference between the standard caliper and this, except the inlet and bleed nipple are reversed, so the nipple is higher.
    You can reverse these on the standard caliper.
    Using the standard master, it was the end of my rear brake woes.
    Sent from my SM-G975F using Tapatalk
    Sep 2009
    Slovakia
    I am interested in this mod too.
    @madart - would you have any picture please?
    Sep 2009
    Slovakia
    I am little bit lost now. I do not know what to change, master cylinder from Duc 848 or rear caliper?
    If the caliper is not leaking and the pistons are not stuck then there is no reason to replace it.
    Dec 2012
    Paimio, Finland
    If the caliper is not leaking and the pistons are not stuck then there is no MECHANICAL reason to replace it.
    Fixed it
    Other reasons, such as star alignment and the color of your socks, are easy to find.
    Mille Aarrr -02 (1060 BB, Gen2 heads, 2-2 Akra, timed cams, bespoke Gabro chip + TSS slipper) & KTM 625 SXC -05
    SoCal
    I swapped mine because it was Tuesday.
    see ya later,
    tony
  1. Will relocating the rear master cylinder and the reservoir to fix the brake problem?
    Last Post: 02-19-2005, 09:58 AM
  2. Rear master cylinder
    By TRexRacing in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 12-29-2004, 02:50 PM
  3. stephens day - new rear master cylinder
    By banjaxxed in forum SL1000 Falco Forum (all years)
    Last Post: 12-28-2004, 02:34 PM
  4. Rear master cylinder rebuild Q's
    By saki302 in forum RS50 Technical
    Last Post: 06-11-2004, 04:58 AM
  5. rear master cylinder info.
    By aprilia33 in forum RS125 Euro-archive
    Last Post: 10-30-2003, 04:11 PM
