Results 31 to 45 of 57
Thread: New Garage APE: 2019 Aprilia RSV4 1100F with Akra RaceMap (1st one in USA?)
  1. #31
    Jun 2016
    Los Angeles, CA
    Quote Originally Posted by RENNprd View Post
    Mfg will always provide their safest Rev limiter for road bikes & be compliance. For track bikes, wear/tear its inevitable thus refresh engines are as scheduled... 13,6k to 13,8k it's safe.
    Attachment 382571
    The picture you posted states 13,800 +/- 100 RPM (highlighted in red presumably by you)
    Wouldn't that be a range of 13,700 - 13,900 RPM according to your own statements / provided information as 13,800 + 100 = 13,900 and 13,800 - 100 RPM = 13,700
    Or do I not understand how plus / minus spec or math works?
    '16 Tuono 1100 Factory
  2. #32
    Sep 2017
    Miami, FL
    Quote Originally Posted by pauldayona View Post
    It seems normal with all tuners to raise RPM limits with Aprilia's, all tuners files that I have seen have raised Max RPM. And gas flow is still there at high rpm, so they find there the high horses that sells the tunes.
    If it is wise for the long use of an engine?
    Hello Paul! Raise rev limiters calculated & controlled it's safe. Obviously, hitting the maximum engine rev limiter (even if stock) in a constant continuous engine abuse it's not without risk & it could fail miserably. Most modern ecu's will log time of rev limit and/or will limit max rev in Netrual & per gear used.
    Here's same dyno runs with matching temps & humidity. You will see gains at same RPM.
Name:	2019 RSV4 1100F Dyno SC Project 13-8.jpg
  3. #33
    Sep 2017
    Miami, FL
    Some more pictures.
    Can't have enough DLC Ti valves =)
    Flow bench:
  4. #34
    Roma, Caput Mundi
    surely not mine (but some special owner request). i do some limited play on rev limiter only in Tuono maps. Any year RSV4 is already topped out at safe rpm stock
  5. #35
    Sep 2017
    Miami, FL
    Difference between +2017 RSV4 1000cc vs 2019 RSV4 1078cc throttle body:
    Vs.
  6. #36
    Aug 2007
    San Antonio
    Vs.
    What's the difference?
  7. #37
    Roma, Caput Mundi
    Throttle shafts are shaped, Aprilia says that mod is good for almost 2hp's alone
  8. #38
    Aug 2007
    San Antonio
    I had to zoom in.
    Just that rounding of the shaft?
  9. #39
    Roma, Caput Mundi
    yes, it gives a better flow and "simulate" a bigger TB
  10. #40
    Aug 2007
    San Antonio
    Are they a direct swap on the 17+ 1000s?
  11. #41
    Sep 2017
    Miami, FL
    I guess UK 44Teeth dyno used it’s spot on
    https://youtu.be/j-A7qof-vno
  12. #42
    apriliaforum expert pauldayona's Avatar
    Nov 2013
    Netherlands
    Quote Originally Posted by snikwad View Post
    Not available as part, only complete tb. it's nothing new. A friend did it on is Guzzi V11 ears ago. and he wasn't the first. A bit DIY for the right handed guys. But flow changes, so 4 must be the same. Maybe to difficult for most.
  13. #43
    apriliaforum expert Proctologist's Avatar
    Oct 2014
    Tri-State USA
    Updates on 2019 RSV4 1100F: Dyno tune, Philips HID, and more upgrades on the way.. Many thanks to UniqueSBK located in Miami, FL
    Attachment 381677
    Congratulations.. nice array of toyz you got there. Have fun and enjoy the new ride !
    Today:
    Ducati 1199 Panigale Rosso | Aprilia RSV4-R APRC ABS | Aprilia RSV 1000R (under construction)
    Yesterday:
    Ducati 1098 | Suzuki GSX-R1000 | Suzuki GSX-R1100 | Kawasaki Ninja ZX600R | Suzuki TS185
  14. #44
    Aug 2007
    San Antonio
    Yeah that's what I meant. The complete TBs.
  15. #45
    Sep 2017
    Miami, FL
    Quote Originally Posted by Proctologist View Post
    Thanks!
  1. 2019 Aprilia RSV4
    By Ed / AF1 Racing in forum 2010-2019 RSV4 - All Variants
    Last Post: 07-25-2019, 12:41 AM
  2. New SC Exhaust to Aprilia RSV4 all By 15-16
    By itaduc in forum Other Stuff For Sale
    Last Post: 08-30-2018, 01:07 PM
  3. 2013 Aprilia RSV4 FACTORY With ONLY 1,056 MILES!!! Tons of extras.......
    By FastGuy68 in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 11-09-2015, 08:05 PM
  4. aprilia rsv4 2010 with fairing aprilia art motogp
    By max_italy_80 in forum 2010-2019 RSV4 - All Variants
    Last Post: 11-09-2015, 05:03 AM
  5. 2010 Aprilia RSV4 Factory with Upgrades
    By rholster in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 10-20-2015, 01:04 PM
