Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Questions?
  1. #31
    apriliaforum prov-nov Xoska's Avatar
    Feb 2019
    Poor Country
    I did not understand the part that u said about the mainjet to put 70 then 64 what? isnt 70 toomuch for stage 3 exhaust
  2. #32
    apriliaforum Junkie jixaw's Avatar
    Dec 2015
    Cambridge, MA
    put in a 70 main...it should smoke but not bog...then put in a 68 and see if smoke goes away...if not then...66...all the way to 64 ...you might need to lean out your needle once you have this set
    u will need a new spark plug...get some spares
    2004 Aprilia Mojito Custom 50cc - 65cc Airsal BBK, 17.5 Delltoro PHVA w/echoke, vforce reed cage, Doppler filter, Leo Vince Touring exhaust, Malossi Multivar, Naraku 4000 rpm clutch
    2004 Aprilia Mojito Retro 50cc - 70cc DR BBK ported/polished along w/cases, balanced crank ,19mm PHBG carb, Topperf reed cage, oil pump delete, Polini boost bottle, Doppler Alien eye filter, Motoforce rear shock, Mojito 125 front fork shocks, Turbokit Exhaust, Topperf variator, Malossi Delta clutch, Pirelli SL60 tires and much much more
    2003 Vespa ET2 50cc
    2001 Triumph TT600
  3. #33
    Feb 2019
    Poor Country
    Okey tnx guys,i have question i have at home malossi mhr replica(its not mine so i dont know much about it)do i need to change the crank with it and whats the best setup with it?
  4. #34
    Feb 2019
    Poor Country
    complaining about what?
  5. #35
    Dec 2015
    Cambridge, MA
    Did that ever fix your fueling issue or are you on to another project?
    2003 Vespa ET2 50cc
    2001 Triumph TT600
  6. #36
    Feb 2019
    Poor Country
    Im runing full stock bike rn.When im going to buy exhaust im going to try the thing that u said or someone else i dont remember.
  7. #37
    apriliaforum Junkie joelbo's Avatar
    Mar 2009
    Waterloo, Ontario
    Seeing all this makes me happy my scoot is fuel injected! No messing around with jetting, it just works great all the time!
    Sent from my LG-H812 using Tapatalk
  8. #38
    Mar 2019
    Hungary
    just start to clean the damn carb.probably dirty or choke is hanging. also start clip adjustment from middle position.what colour gives the sparkplug?show us something or make a video.
    Joelbo: ditech has enough issues to deal with so be happy.u better buy reserve parts cuz ditech is out of production.
  1. Kick Stand Question
    By CaliRSV in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-16-2003, 07:27 PM
  2. Need help now! oil change torque question...please
    By 02Prilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-16-2003, 10:43 AM
  3. A Couple quick Renegade/Leo Vince questions
    By Maxx in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-14-2003, 10:48 PM
  4. Question about MotoGP
    By RSVR 02 in forum Professional Racing Discussion
    Last Post: 04-24-2003, 12:11 PM
  5. moved RS50 question to RS50 board
    By ed apriliaforum com in forum Professional Racing Discussion
    Last Post: 06-27-2002, 10:06 AM
