Page 1 of 4 123 ... LastLast
Results 1 to 15 of 50
Thread: Questions?
    apriliaforum prov-nov Xoska's Avatar
    Feb 2019
    Poor Country
    Question Questions?
    So its me again...Only one that posts and bother other people.So i have question is any clone/chinese carbureator of the dellorto carb good?I saw them on ebay for like 30 50 .Idk are they any good
    apriliaforum Junkie joelbo's Avatar
    Mar 2009
    Waterloo, Ontario
    Quote Originally Posted by Xoska View Post
    From other posts I've read, the cheap Chinese ones are just that! If you care about your scoot, best go for the high quality ones. If you go for a cheap one and it breaks, it could break other important parts.
    Sent from my LG-H812 using Tapatalk
    ontario
    ^^ perfect timing ^^
    i agree 100%
    the answer is in the detail of the small parts quality or quality control. I saw a garbage one where the entire slide assembly was a disaster. To bad, better luck next time... not something that would be obvious either.
    --- custom parts and machining
    -2T&4T cylinder&engine prep,port,polish,balancing,blueprint,tuning
    -derbi bullet 2006 - piaggio AC
    Feb 2019
    Poor Country
    Thanks for the information guys.
    Feb 2019
    Poor Country
    I have One more question!Soo my carb dellorto 17.5 stock on piaggio engines isnt working right i cant ajust it the screw for theadjusting the rpm that the bike is working on its like not working,not the mixcure screw the other one the bigger.My scooter is going slower that the other scooters with piaggio engines woth the same setup of mine.Ive tested another gilera the same year as mine it was going faster than mine.So my question is if ly carb is broken is that the main reason why my bike goes slower.Thanks and SORRY FOR MY BAD ENGLISH!
    ontario
    Mostly the problems would be things like reed valve, carb and specifically the jets and atomizers need to be cleaned. Finally and air cleaner unit maybe no longer matches the needle on the carb. The Doppler filter I suggest is pretty close to what is needed on the 17.5 carb because it has a 17.5mm tube. Likely lose a bit of low end in favour of topend but show me something better...
    perhaps the doppler filter and vforce should be you first purchase if performance is your primary goal.
    Feb 2019
    Poor Country
    Can you send me link from that doppler filter and vforce pls i cant find them
    Feb 2019
    Poor Country
    ontario
    Correct site but negative on both items.
    -The topperformances 8 reed valve
    -The Doppler Filter with the mesh top not the dome top. And I must warn you it fits piaggio perfectly but the other engines need to be mounted with custom tubing from the stock air box or something.
    Feb 2019
    Poor Country
    I have gilera runner 2013 piaggio hyper 2 engine lc will it fit corectly.My stock airbox is the smaller one that the newer piaggio hyper 2 egines have.
    Feb 2019
    Poor Country
    This filter ? https://www.scooter-attack.com/doppl...473482-39.html
    but there is no topprefomance 8 reed valve on scooter attack ingeneral there is not topperformance intake parts
    is there replacment for the topreformance 8 reed valve
    ontario
    That’s correct yes, I like all the colours except the silver myself. I believe it will drop in yes. I keep saying that thou and people have issues with the shock location or something. Mine it fits like a glove. It is absolutely worth it to get it to work. It sounds nice a low and snarly standing beside the bike. From a ways down the street it sounds healthy and stock.
    Feb 2019
    Poor Country
    And one more question is there a replacment reed valve for the topreforamce 8becouse there is not toppreformance intake parts on scooterattack
    Feb 2019
    Poor Country
    And can i run this setup(the arifilter and the red valve sorry for asking im new in tuning ) on stock 50 cc with 60 mainjet on 17.5 dellorto multivar with currenty 6.5 grams rollers gonna put lighter rollers and a polini scooter team.
    ontario
    Try not to run lighter than 6.5g
    7.2g is better and 7.5 is better still if you run well enough to pull it.
    The valve will bring more power so if anything you might want heavier ones if you could pull them. Likely not till 70cc.
    Naraku 4k clutch would be a good purchase. As would the malossi 5k clutch if you like high performance pipes
  1. Kick Stand Question
    By CaliRSV in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-16-2003, 07:27 PM
  2. Need help now! oil change torque question...please
    By 02Prilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-16-2003, 10:43 AM
  3. A Couple quick Renegade/Leo Vince questions
    By Maxx in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-14-2003, 10:48 PM
  4. Question about MotoGP
    By RSVR 02 in forum Professional Racing Discussion
    Last Post: 04-24-2003, 12:11 PM
  5. moved RS50 question to RS50 board
    By ed apriliaforum com in forum Professional Racing Discussion
    Last Post: 06-27-2002, 10:06 AM
