Results 1 to 10 of 10
Thread: "Don't drain fuel tank"
    Harvard, MA
    Why does the manual that came with my 2003 Tuono R warn you not to ever drain the fuel tank?
    Aug 2010
    Chojnice POLAND
    Because you will need to push it home
    Wysłane z mojego SNE-LX1 przy użyciu Tapatalka
    Oct 2004
    Vista, California, USA
    Maybe because they know what an immense PITA it will be to reinstall it?
    apriliaforum Junkie Stevex's Avatar
    Jun 2016
    North Yorkshire, England.
    I've drained mine and removed it before, no problem. Just need to replace the pressure line banjo alloy washers with new ones at the throttle bodies.
    Where exactly do you find that? In a digital version of the 03 manual I have it says, "Never try to siphon gasoline by sucking it with your mouth. Use a manual pump or a similar system." First page under Main Components.
    Any way, I think many of the warnings in the manuals are just to try and prevent people from doing stupid things.
    Aug 2014
    Central Ohio/ Aprilachia
    do it and let us know when you find out.
    I think long bike histories take up too much space to copy on every post
    What's to find out. I have drained my tank several times. It's a tank with gas in it. Use your head. Don't drink the gas. Don't go probing around in the tank with sharp or otherwise damaging things.
    Oct 2004
    Uh, is gas flammable? Can't quite recall.
    Jun 2016
    Florida
    Service manuals are funny like that. Many folks read them like a "bible" if they have no practical experience. Those with practical experience and a healthy appetite for curiousity will giggle as the suggestions. I always like folks that bust out the torque wrench for bolts requiring 8 ft lbs...lol
    Quote Originally Posted by turboblew View Post
    ...I always like folks that bust out the torque wrench for bolts requiring 8 ft lbs...lol
    Yeah, torquing 6mm and smaller screws is is troublesome. If you don't have a precise low value torque wrench you will get into trouble. Most people do not know that even very high quality wrenches are only accurate in the upper 80% or the range. So a fifty pound wrench is not safe to use for 8 ftlb. I have a 150 inch pound wrench that I use for 6mm if I feel the need and even then never torque to full value. Generally torque values are for new dry parts. So, on the second assembly less is better. I have never used a torque wrench on anything smaller than 6mm. There are tools for it but I don't have them and have never felt the need.
  1. Draining fuel tank- easiest, best way
    By ridinginstyle in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 02-03-2017, 09:57 AM
  2. Scarabeo 100 4t need to drain fuel tank and carb...
    By messicl in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 02-23-2016, 07:09 PM
  3. Best way to drain fuel tank?
    By Bear King in forum SL1000 Falco Forum (all years)
    Last Post: 01-02-2016, 08:27 PM
  4. Draining Fuel Tank
    By Diablo1 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 11-20-2015, 06:46 AM
  5. easiest way to drain fuel tank
    By shultram in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-19-2009, 02:26 PM
