Results 1 to 8 of 8
Thread: fork tube removal
    Jul 2008
    The Hood, Ca. USA
    fork tube removal
    howdy everyone,
    i'm trying to get the front fork tubes off to take for new seal. the wheel is off and all associated brake stuff. the pinch bolts are super tight or they used some crazy locktight goop. the top ones are not an issue. the ones on the lower tree are a real pain. i have removed the plastic tray that holds the horn for better access. i'm afraid of stripping out the allen head while trying to loosen them. one in particular. i can't get a ratchet with a hex key bit up in there. am i going to have to remove the front light assembly? has anyone else done this?
    also is there any sequence/trick for removing the electronics from the left tube?
    Dadsafrantic
    2015 Red Caponord #64
    Sep 2014
    MA
    I’d try penetrating oil on the threads and also on the bolt heads. A little in the clamp gap wouldn’t hurt either. Those bolts shouldn’t be very tight (18.5 ft lbs); there’s a good chance you’re dealing with mild corrosion/seizing, and penetrating oil might help a lot.
    FWIW, WD 40 is better than nothing, but not nearly as good as a purpose made penetrating oil, like Liquid Wrench.
    Jul 2008
    The Hood, Ca. USA
    Quote Originally Posted by Motoespresso View Post
    cool espresso. i thought about that while walking my dog in defeat. it could very well be some corrosion. it has some miles through all types of weather. the pinch bolts for the front axle ere definitely corroded. thanks for the tip.
    Dadsafrantic
    apriliaforum Member Funtik's Avatar
    Apr 2016
    Russia, Moscow
    I did it. Don't use ratchet - it is useless, there is not space for it.
    First high torque movement I did with this:
    Name:  Screenshot 2019-05-12 04.38.42.png
    then I made it with typical hex key.
    It is not fast, but works.
    As for disassembling the leg - you will need special head.
Name:	Screenshot 2019-05-12 04.44.42.jpg
    Of course that was not my way, so I bought another tool for ratchet (check the pic below, the only difference - I found U-shape)
Name:	Screenshot 2019-05-12 05.09.23.jpg
    Aprilia RST Futura 2003, Ash Gray.
    Aprilia Caponord 1200 Travel pack 2014, Red
    Jul 2008
    The Hood, Ca. USA
    thanks funtik. i've used the penetrating stuff and it's soaking now. i'm off to buy another tool. i'm having a suspension shop handle the guts of the matter. they do a lot of aprilias and others. i've used them before.
    https://superplushsuspension.com/
    Dadsafrantic
    apriliaforum newb TheoCal's Avatar
    Jan 2016
    Northern California
    Sep 2014
    MA
    That reminds me - it is a lot easier loosening fork caps while the forks are clamped than after you remove them; then you don’t have to worry about how to clamp your nice, smooth fork tubes in your rusty home shop vise. Ditto for the final tightening.
    Sam
    Jul 2008
    The Hood, Ca. USA
    that makes sense.
    Dadsafrantic
  1. How to remove fork tubes from triple tree on Aprilia SC 250?
    By Vic5491 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-13-2018, 04:49 PM
  2. AA500 fork tube removal
    By Phelps in forum Aprilia and Piaggio 500cc
    Last Post: 02-09-2013, 09:14 AM
  3. ohlins fork tube diam.
    By farva03R in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-10-2005, 10:35 PM
  4. raised fork tubes, now head shakes
    By DanB in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 08-24-2004, 07:25 AM
  5. Improved handling with raised fork tubes
    By YumaNord in forum ETV1000 CapoNord (2001-2007)
    Last Post: 07-19-2004, 09:55 AM
