Results 1 to 8 of 8
Thread: Battery Upgrade - ENTX14-BS
    May 2019
    Essex
    Lightbulb Battery Upgrade - ENTX14-BS
    Iíve seen a battery thatís showing as being compatible as a replacement for the YTX-14 BS
    Outlining figures and size remain the same, yet with a greater Amp output of ~165Amps
    Anyone ever encountered this, tried one ? Or have any stories to tell of success or failures ?
    apriliaforum Junkie Ario's Avatar
    Poland
    I had Yuasa for some time which was not great. Two years ago I switched to Tuborg with 220A CCA. Works better and still holds.
    Wysłane z iPhone za pomocą Tapatalk
    apriliaforum Junkie Stevex's Avatar
    Jun 2016
    North Yorkshire, England.
    A new battery is only half the battle; fit the up graded starter motor / earth leads and 150A starter relay as well.
    I've had the Yuasa fitted since buying my Gen 1 T, and the wiring up grade; its always started first prod, even after winter lay ups.
    Poland
    From the upgrades mentioned above I have the 150Amps starter coil only.
    Apr 2010
    california
    May 2019
    Essex
    That’s mega !
    Thanks for the info info and assistance, I’ve done the battery cables but haven’t looked at the starter relay or motor yet.... after replacing the yuasa battery a few times in the last 3 years I’m just going to swap everything out !
    Thanks for for your help all ��������
    Jun 2016
    Shindengen is next on my list. I've bought an FH014AA, just getting all the wiring, connectors and fuse holder together slow time.
    Dec 2015
    Ireland
    The Yuasa TTZ 14S is probably the one I'd reccomend.
    The spec sheet claims 230 CCA, it's lighter and shorter than the YTX 14-BS but with slightly less capacity.
  1. battery upgrade question
    By Thom in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-25-2012, 02:31 PM
  2. Way Better Battery Than YTX14-BS
    By Berto in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 10-19-2011, 09:19 AM
  3. 06 SR 50 Ditech BATTERY UPGRADE to YUASA YB9-B?
    By CountChocula in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-20-2011, 10:17 PM
  4. Battery upgrade for Caponord
    By Stu_O in forum ETV1000 CapoNord (2001-2007)
    Last Post: 05-12-2010, 11:08 AM
  5. Battery Upgrade
    By 06spidey2 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-26-2008, 12:23 PM
