Results 1 to 5 of 5
Thread: Replace Dashboard for 1200 from new 900
    Sep 2018
    Ho chi minh city, Vietnam
    Hi All,
    I would like to replace dashboard for my DD1200 by new one from DD900 but I dont know if it is possible or not.
    Anyone has experience about that? Please help to share any information if you know.
    THanks,
Size:  85.6 KBClick image for larger version.
    Nov 2016
    Lincoln
    You will in all likelihood need the ECU and loom off a 900, then remap it to suit the 1200.
    This because I expect the connectors will be laid out differently, if not completely incompatible, for the two different dashes. You could cause some serious damage if you don't make sure, via a wiring diagram etc., that they will go together.
    Also, the older 1200 ECU might not know how to talk to the newer 900 dash anyway.
    2009 Shiver (White) | UK
    apriliaforum expert pauldayona's Avatar
    Nov 2013
    Netherlands
    First compare wire diagram of both bikes.
    Jan 2016
    Vancouver, BC, Canada
    Redline wrong by 1300 rpm also.
    Nov 2016
    Lincoln
    The 900 and 1200 have the same approximate limit: 9500 rpm. Which might be related to their sharing approximate crank stroke dimensions.
    Otherwise it's fixable with a remap in any case.
  1. New map for 1200 available!
    By lanter in forum 2011-2012 Dorsoduro 1200
    Last Post: 08-17-2018, 08:42 AM
  2. A new Caponord 1200 from a German preparer.
    By andydj31 in forum 2014-2017 Caponord 1200
    Last Post: 01-25-2014, 04:25 AM
  3. Replacement key for New Concept Top box
    By gestnerd in forum Aprilia News and Product Discussion
    Last Post: 06-14-2013, 07:42 AM
  4. replacement clocks/dashboard for sale on fleabay
    By 20N0 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 11-13-2009, 06:24 AM
  5. Replies: 2
    Last Post: 05-17-2009, 12:46 AM
