Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: HELP:Strada 2005:Accidentally stops with 5kRPM, Dashboard shut down in the same time.
    Jun 2018
    Skopje
    Can we use this type of connector
    Jul 2011
    shropshire UK
    The type of connector is good, waterproof connections and held locking connector. what isn't explained is the amount of current the connectors allow.
    The reg/rect pushes out a lot of current in comparison to what is needed on the bike. similar connectors such as those that connect the fuel pump are probalby too small.
    Best to judge it by size of wire the spades/connectors will recieve after looking at the current wire dimaters. Some of the wires on the reg/rect are quite wide so 2mm might be a good max limit.
    Again, purely my suposition, but at least I have thougth about it!
    Cheers
    Dave
    “If it looks like a duck, and quacks like a duck, we have at least to consider the possibility that we have a small aquatic bird of the family anatidae on our hands.” Douglas Adams
    Jun 2018
    Skopje
    I am also suspecting that it is not big enought, maybe the best solution is solder and it should not give headaches.
    apriliaforum expert ytc1's Avatar
    May 2010
    St Helens, UK
    Quote Originally Posted by dobbi View Post
    Cheers
    Dave
    All hail Dobbi and his electrical suppositions :-)
    I've tried various sealing of the rectifier connections, initially a combination of wrapping them in inner-tube+sealed plastic bags seemed to do the trick. That survived the Americas (both bikes).
    However it had the downside of allowing some water ingress and then not letting it go, hence the breakdown in Semey, Kazakhstan. This was repaired by a friendly bike gang, and they used sealant to block off the connectors. This has held since then (2013). Similar has been done to the other two Pegs in advance.
    A square Peg in a round hole - http://ytc1.blogspot.co.uk/
    Jun 2018
    Skopje
    Quote Originally Posted by ytc1 View Post
    Sealant as a silicone sealant? Where did you filled it, in the back of the connector?
    Jul 2011
    shropshire UK
    I was wondering how you have got on as I'd never heard you'd had problems with it.
    Silicon is ok as long as you don't want to disassembe. if you do, it leaves you with a massive clean up job to ensure you haven't trapped silicone between the contacts, reducing current, increasing heat and therefore corrosion. I'm sure there are good quiality high current.
    The generator pumps out 290W so that is a little over 24A of current. You will need to find a connector which will cope with a little more.
    May 2010
    St Helens, UK
    Proves you never read the blog :-P
    Buggered if I know what type, I was drinking vodka.
    UK mechanic will have used correct stuff, he was an electrical draughts man at sellafield in a previous life :-)
    Sent from my Moto G (5S) using Tapatalk
    apriliaforum prov-nov Heath12's Avatar
    Mar 2018
    Lancashire, England
    Don't worry about the rain, mine has had plenty.
    Yes there are "scare" stories, but remember it is generally people asking for help on here so it will look worse than it is in reality
    True. No one ever posts to say everything is great. Mechanically they seem pretty solid as not much reported on here. Always seems to be electrical.
    Dec 2018
    Spain
    Quote Originally Posted by Heath12 View Post
    The Minarelli engine is a marvel of engineering....best single engine ever IMHO.
  1. My Pegaso strada 2005 problem - please help!!!!
    By roly01 in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 03-28-2014, 07:00 AM
  2. Bogging down in the power band then stopping?
    By nathan k in forum RS50 Off Topic
    Last Post: 10-30-2012, 04:22 PM
  3. 2005 RSVR Factory with many extras (British bike in Germany)
    By Kristian_AUS in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 12-11-2010, 03:37 PM
  4. video of cop stop- may get you 5 years in the pokey
    By yzf29 in forum General Motorcycle Talk
    Last Post: 05-25-2010, 08:07 PM
  5. 54mm T.B.'s with "Hooked Air Box Kit" in the for sale section
    By angelo1000r in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-07-2009, 09:07 AM
