Results 1 to 1 of 1
Thread: Transmission 'clash' going from 1st into 2nd gear or from neutral into second gear
    Feb 2009
    NE Maryland/SE Pennsylvania
    I just got my bike back from the shop where a new shift shaft was installed. The problem was that it would not shift out of first gear.
    Here's the problem now. As always happened, when I shift from neutral to first there is a 'clash' as the gear is selected. This has always happened and happens on other bikes I have. The new twist is the 'clash' happens now when I shift from 1st to second or from neutral to second. All other gear changes are fine.
    Any easy adjustments I can make? The shop is closed today and I have only a couple of days before my first track day of the year.
    Issue resolved. Non-problem .
  1. trouble changing from 1st to 2nd gear?
    By jazz in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-26-2014, 04:42 AM
  2. 1st and 2nd gear taller - new production
    By Biagio in forum RS250
    Last Post: 12-10-2013, 08:11 AM
  3. Only got 1st and 2nd gears
    By swerver in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-22-2013, 07:09 AM
  4. sometimes when i go from neutral to 1st engine cuts out
    By matt_uk in forum RS125 Euro-archive
    Last Post: 02-16-2007, 08:28 PM
  5. 1st and 2nd gear hiccups
    By nobrakes in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-20-2004, 07:30 PM
