Results 16 to 30 of 31
Thread: 2004 Tuono rough running issue
    Sep 2009
    Slovakia
    hey both....I wanted to look in the ECU of my Tuono today to check what type of chip is there. I was not able to unlock the screws, nevermind, but I have seen ECU trimpots set to 3 & 4 o clock. regarding to what I just read above, it looks to be wrong. But the first it would be the best to know whether any aftermarket chip is not included, am I right?
    Besides of this, the green/blue wire is cuted.
    apriliaforum expert madart's Avatar
    Aug 2011
    Australia
    It's a bit hard to say without knowing what chip is in it, but regardless, 3 and 4 o clock sounds very rich. Are you getting bad fuel consumption?
    I'd be setting both of them back to 12 o clock. Testing adjusting and retesting.
    Follow the procedure as Gabro describes.
    Sep 2009
    Slovakia
    I did not realized higher comsumption, but I will check.
    thanks anyway, I will try and will also try to get into the ECU. Anyway, I have got Arrow chip ready to put into the ECU, I assume the Gabros setting should be the same?
    Aug 2011
    Australia
    Quote Originally Posted by kralik View Post
    Gabbro makes different chips for different setups (exhaust, intake, throttle body etc.). Some have two maps which require joining up that cut wire and putting a switch in.
    I haven't experience with the Arrow chip. But I think with any of them, starting at that twelve o clock position would be advisable. It's a default between rich and lean so the logical setting to start to tune.
    Sep 2009
    Slovakia
    thanks mate!
    apriliaforum Junkie Stevex's Avatar
    Jun 2016
    North Yorkshire, England.
    Trim pot adjustment has no effect with some chips fitted in the ECU; you need to find out what chip you have.
    The only way to set the trim pots accurately if you have a chip that allows, is to get your O2 levels checked and adjusted using an exhaust gas analyser.
    Sep 2009
    Slovakia
    Quote Originally Posted by Stevex View Post
    Thanks! Then the first job for me is to open the ecu as I was not able to do that. Somebode overtighten the screw
    Odoslanť z SM-G390F pomocou Tapatalku
    Jun 2016
    Just remember to earth yourself before touching anything in the ECU when you get the top off.
    ...The only way to set the trim pots accurately if you have a chip that allows, is to get your O2 levels checked and adjusted using an exhaust gas analyser.
    There is another approach for those without access to a gas analyzer. It really works very well. Great cold and hot starting characteristics. Great idle. Great off idle throttle response.
    http://www.apriliaforum.com/forums/s...57#post1883457
    Sep 2009
    Slovakia
    What is the best way to earth myself?
    Jun 2016
    Touch something like a central heating radiator or a concrete garage floor; you're just aiming to dissipate any static build up in your body instead of it damaging the chip or ECU component.
    I actually felt a static discharge the other day when I put my hand under a running cold water tap.
    Yes, any water pipe will do. I got a shock recently from running water as well. Didn't know that was possible.
    Sep 2009
    Slovakia
    Ok, I understand now. Thanks, I will do that. I think, also using the rubber gloves could help to prevente this type of damage.
    Sep 2009
    Slovakia
    I have finaly got into the ecu and found the same chip I wanted to put in.
    Does anyone of you know what does the sign on the ecu stands for? See the trim position too.
    Sep 2016
    Los Angeles
    Update for anyone interested:
    Previous owner deleted the Charcoal canister and ran the tank vent straight to the throttle body.
    Capped that off properly and it rides significantly better! Need to fine tune the sync still.
  1. Tuono intermittent rough running.
    By jazzym71 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 06-02-2017, 06:03 PM
  2. 2004 Tuono 1000 Tail light not working (running light)
    By Bociba in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-21-2015, 02:33 PM
  3. [Tuono] 2004 Tuono - Seattle-ish $3300
    By router.exe in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 06-06-2014, 01:32 PM
  4. Rough running 04 Tuono
    By Moonpie in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-24-2012, 02:39 PM
  5. my tuono is running rough!!! any tips
    By stangbanger00 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 08-16-2009, 10:41 PM
