Results 1 to 15 of 23
Thread: ET6188 Tail Tidy Installation, Evotech for Shiver 900
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    Austin, Texas USA
    This is a picture heavy thread showing the high points of installing an Evotech 6188 tail tidy on the Shiver 900 MY18-19
    9900 North Interstate 35
    Austin, Texas 78753
    direct:512-459-3966 fax:512-482-8319
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
    Austin, Texas USA
    Remove the two pan head shouldered bolts seen in the image below (Allen key inserted into the bolt on the right)
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    There is a third pan head shouldered bolt accessed from beneath. Once you get it loose, the entire assembly will hang like so:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    The Three clip nuts that support the OEM license plate support visible in this photo. These are the same mounting points used by the Evotech bracket.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Unbolt turn signal
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Use P1 Phillips head screwdriver to remove lens. Gently remove lens. Then pull out reflector like so and disconnect wires at the reflector.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Unscrew license plate lamp housing (you will not re-use this coarse threaded screw):
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Wiring sub-harness removed from the stock license plate support.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    License plate light housing fitted to the Evotecth Tail Tidy (evotech provides the bolt)
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Note that the turn signals have a swivel off foot. Remove the foot.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Fit the turn signal to the tail tidy. Reconnect the wires (polarity not important)
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Insert license plate light into license plate light housing.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Prepped Evotech tail tidy, ready to install.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Evotech says to flip this clip nut so that the Evotech support bracket can be installed (we used an M5 nut [not included] and an m5 washer [included])
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Image of flipped clip nut.
    Austin, Texas 78753
    Currently:
    Previously:
  1. Evotech Tail Tidy installation for 2015 Shiver?
    By 1stscoot in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 05-10-2016, 12:29 PM
  2. RSV4 / TUONO Evotech tail tidy + other parts for sale
    By Ccraigy46 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 08-26-2012, 02:52 AM
  3. Evotech Tail Tidy Installed
    By exploring/nc in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 02-11-2012, 12:37 PM
  4. evotech tail tidy install
    By ovic in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 11-15-2010, 06:02 PM
  5. evotech tail tidy installation
    By newtomoto in forum 2010-2019 RSV4 - All Variants
    Last Post: 04-25-2010, 01:50 PM
