Page 11 of 11 FirstFirst ... 91011
Results 151 to 165 of 165
Thread: Aprilia RS4 50 tuning problem
  1. #151
    apriliaforum prov-nov Doser's Avatar
    Jan 2019
    Latvia
    Today do test with new spark plug. 1km full throttle on 5 speed 105 km/hour. What do you think about it? Short test or lean main jet?
    This spark plug after 2 days in city use. Looking little rich.
Name:	IMG_1483 (изменено).jpg
    Aprilia RS4 2011, Malossi MHR Replica 79cc, Top Racing (Jasil) crankshaft, Polini 21 carburetor, Polini reed valve, Polini intake manifold, Stage6 boost bottle, Polini clutch, Giannelli exhaust , 14/53 gearing.
  2. #152
    Apr 2010
    San Francisco
    The first one does look rich, but second one looks fine. In general for a street bike to be a little bit on the rich side is a good thing. That way it can deal with some atmospheric changes.
  3. #153
    Jan 2019
    Latvia
    Oh my God! Looking what cooland come again. And looking so what during 2 days street use not come, but after run on big speed come again (high rpm).
    How much Head nut torque? In Polini manual nothing, I use Aprilia manual value 19Nm. (19-22 Nm)
    Now I tighten till 22Nm. Will do one more test today.
  4. #154
    Apr 2010
    San Francisco
    What does the bottom side of the head insert look like? Do you have a photo?
  5. #155
    Jan 2019
    Latvia
    Hello, ToraTora.
    After head tighten till 22Nm not have leakage. Was tested during some days till 100km/hour speed, about till 10000rpm. Still not tested on full rpm range till 13000.
    I remember from fist day use of Polini kit, we had this problem with leakage on big rpm. It was hard to see, where the leak came from, but now I sure it was.
    Today I received new gaskets set from Polini, but if not have leakage in future I not will change our installed gaskets. Under the head kit have only one O-ring.
  6. #156
    Jan 2019
    Latvia
    If anybody have thinking about my problem, please help with idea. Coolant come again, I not have ideas any more.
    If I understand correctly, I have two variants of coolant leakage to crankshaft :
    1. Under head
    2. Under cylinder
  7. #157
    Jan 2019
    Latvia
    My thoughts:
    1. Pressure of standard pump very big on big rpm, need to change on electric.
    2. Polini kit have problems (defective). New gaskets not help.
    3. Problem with pressure in the cooling system > radiator plug 1bar
  8. #158
    Jul 2019
    Northampton UK
    well depending upon your max revs Doser has made some valid points
    these issues can be very frustrating.
    go right back to basics
    are all of the mating surfaces still flat? check very carefully even a minor warp can be a major issue
    are you using a jointing compound as well as the gasket set?
  9. #159
    Apr 2010
    San Francisco
    If you get a fairly new piece of glass you can check to see if the mating surfaces are flat. If they are not then you can use some sand paper laid on the glass to make sure you have a flat plane with which to remove some issues (if they are small enough). But if you have warped the head, say from over heating, then it might be easier to replace it.
    I think Kaldis was having a similar issue with his bike. You may find some answers in his project thread.
  10. #160
    Jan 2019
    Latvia
    Quote Originally Posted by anotheronetoday View Post
    usually I not use any sealant with new gaskets. Only if use old gaskets put sealant. Better use new gaskets always.
    I try check surfaces and canít find curved surface.
  11. #161
    Jan 2019
    Latvia
    Quote Originally Posted by ToraTora View Post
    Hello, ToraTora. Kaldis issues show me what if problem with o-ring, bubbles come to coolant. I think have leakage in another place.
  12. #162
    Jan 2019
    Latvia
    Was good price and I did not have the patience to work with the Polini cylinder further.
  13. #163
    Nov 2018
    Lanarkshire, Scotland
    Good luck with new kit, have you had a chance to try it out yet ?
    Is it an aluminium cylinder ? I know the malossi kits are meant to be good
    2010 TZR50 70cc Top Performances Trophy
    21mm CP
    Technigas ebox
    Top Performances reeds
  14. #164
    Jan 2019
    Latvia
    Yes, both aluminum. We use Malossi kit some days already. Looks like Polini, may be slightly less power. On this moment without leakage.
    Like me 4 nut over the cylinder cover. This all for cylinder and cover tightening, not need tight many screws.
  15. #165
    Apr 2010
    San Francisco
    If switching kits fixed the leak then it probably wasn't a main seal, but you should check them anyway since the seals could have been blown out.
  1. Aprilia rs4 50 starting problems ??
    By shayne_harrison in forum RS50 Technical
    Last Post: 12-10-2016, 03:17 AM
  2. Aprilia RS4 50 Reliability Problem.
    By FMXER in forum RS50 Technical
    Last Post: 12-01-2013, 10:20 AM
  3. Aprilia RX 50 Tuning Help ?!?!
    By BettisBoy in forum Other Aprilia Models
    Last Post: 11-04-2010, 05:37 AM
  4. aprilia rs 50 rev problem
    By chopper rs in forum Bimota Motorcycles
    Last Post: 07-26-2010, 11:57 AM
  5. Possible NEW solution to Scarbeo ditech 50 tuning Problems
    By steelopads in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-12-2003, 04:04 PM
