Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: 2010 Beo 500ie won't crank
    Clearwater, Fl
    You do have to roll up your sleeves, pick a starting point and work through it methodically. The brake switches are probably a good place to start from and if you find power going into them then work you way forwards otherwise backtrack. Its tedious but still pretty basic troubleshooting.
    Bear with me but has the bike ever run for you or have you had this one for a while and its acting up all of a sudden? Whats the chances that some form of vermin got inside the tupperware and chewed on a wire?
    Feb 2005
    SouthCarolina/Tennessee/Florida
    Thanks, Rocky......yeah, I've had the bike basically since new and never had any kind of an issue with it starting, etc.
    So, yes, it is suddenly acting up. I guess a vermin may have chewed on something as a possibility and will be looking for any frayed wires also.
    Meanwhile I am riding my ole Rotax Beo 150, and will work on resolving the issue on the 500ie
    Vernon
    Jan 2016
    St. Petersburg, FL
    Vernon,
    I know you said that you're not getting a beep when you hit the security button on the keyfob, but have you looked and made sure the immobilizer indicator light is going off on the dash? Your fobs may need to be reprogrammed.
    Feb 2019
    NJ, USA
    Ever get this sorted out?
    Sent from my SM-G950U using Tapatalk
    Feb 2005
    Not yet bukaka.....but am thinking it probably is the sidestand switch gone out on me. Into taxes now......grrrrrr.
    Will apprise when resolved
    Vernon
  1. S500 Won't crank
    By kfreed in forum Aprilia and Piaggio 500cc
    Last Post: 10-05-2013, 06:43 AM
  2. Help! Front wheel wobble on my 06 Beo 500ie
    By MADEXIT in forum Aprilia and Piaggio 500cc
    Last Post: 06-04-2008, 04:24 PM
  3. Beo 500ie glitch found
    By baadaaboo in forum Aprilia and Piaggio 500cc
    Last Post: 05-26-2008, 07:00 AM
  4. deposit on Beo 500ie
    Last Post: 04-07-2008, 03:08 PM
  5. SXV 4.5 stalls and won't crank
    By Falken Hawke in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-31-2007, 02:58 AM
