Results 1 to 3 of 3
Thread: Griso 850
    Dec 2015
    Sydney
    Griso 850
    Is there any means or method to turn an 850 Griso into a larger bore 940 or 1200?
    Just curious because high kilometre ones come up for quite cheaply at times.
    Anything is possible but it won't be easy.
    Unlike the old Tonti's that maintained the same stroke for a decade or more all the different 2V CARC bikes use a different crank and consequently different piston deck heights. Rods are, from memory, all identical. There would also be balance issues if you tried to simply put a new top end on to the 850 bottom end.
    Converting an 850 to a 1200-8V would also require a host of other parts. Gearbox, clutch, throttle bodies to name just a few.
    Thing is Chris the 850's are actually quite a happy thing. They are even happier if you buy a pair of twin discharge coils and add another plug each side and map accordingly. All the 2V bikes apart from the Bellagio use the (IMHO) superior throttle body set up as well which I think is a big advantage. Griso suspension, especially when set up properly, is greatly superior to Bellagio. Like the Bellagio the trick is to just hold the throttle wide open until they go 'Blurp!-Blurp!-Blurp!' And then grab the next gear.
    Pete
    Professional Goat Burster.
    Dec 2015
    Sydney
    Thanks Pete, very informative as usual.
  1. MG Release The New Griso
    By morelli in forum General Motorcycle Talk
    Last Post: 09-26-2005, 03:39 PM
  2. duc s4r or wait for griso
    By Nube in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-29-2004, 04:00 PM
  3. Griso: Here!
    By Ricky J in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-18-2003, 12:00 PM
  4. Any word on the 850 Twin ?
    By Pauls 500 NYC in forum Aprilia and Piaggio 500cc
    Last Post: 07-17-2003, 03:24 AM
  5. Aprilia 850
    By Fabster1 in forum Aprilia and Piaggio 500cc
    Last Post: 07-08-2003, 12:16 PM
